Help! Ac Radio Finisher Circuit or Loose Wire?
Hi Guys
For the last year I've been having an intermittent issue with my ac and radio going on and off. Several times I've hit the side of the hvac and everything would come back on. It no longer responds to my light abuse.
Today I removed the HVAC and the 4 main connectors on the back were firmly in place, I have yet to dissect down to the circuit board and see if anything else is out of place.
Is this a typical symptom of a bad circuit board?
If this is not typical then aside from the 4 main connectors, what else should I check?
Thanks!
Thanks!
yes, the circuit board is the problem your solution is to get a DD kit with a HU and you won't have this problem anymore. If you even going to get another one it might work for couple of months and then it will go again.
After removing the HVAC unit I noticed that the bottom right (when looking at the 4 connectors) is not connected nor is there a connector that will fit it. Is this normal?
I've completely lost all control of the stereo from the steering wheel controls(this symptom started prior to the removal). I've always been able to control the stereo via these controls even when the board goes bonkers.
I've checked the fuse underneath the drivers side and in the engine bay. Is there anything else I can check?
I'd love to go double din but unfortunately cannot afford it at this time
You are describing the death of your HU/HVAC circuit board. At first the control panel would stop working but the radio would operate and could be controlled by the steering wheel buttons. Sometimes it would cut back in and everything would be fine. Then one day everything stopped working altogether.
The open connector you see on the back of your HU is for the satellite radio/ipod connection.
Thanks for the help guys.
dam it man i got an 03 sedan and had the cd player fixed once for 250 now i got the same problem, cd player is out and i don't have control over the ac its on auto on high can't stop it =[ breaks my heart INFINITY WHY DO YOU DO THIS TO ME!!!
Freeman186
Sep 6, 2023 10:07 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
