PAC SWI-X install question.
Old Jul 7, 2008 | 07:44 AM
G35 Mass's Avatar
PAC SWI-PS install question.
So I downloaded the install instructions for the PAC SWI-PS interface, which I will be installing over the weekend.
Here is a link to the instructions: http://www.pac-audio.com/swixprogram...ehicles&ID=211
It states: "Read only note # 1 in the below chart. If it is blank then skip to next step. The other notes in the chart do not apply to your vehicle. Connect a 150 ohm resistor to pin 23 (Green). Connect a 47 ohm resistor to pin 22 (Red). Connect remaining ends of resistor to the INTERFACE's White wire. Connect pin 25 (Yellow) to chassis ground."
Now, I found some posts where people noted that their instructions indicated NOT to use resistors.
A little help? This if for an 03 sedan.
Old Jul 7, 2008 | 07:56 AM
Gilley's Avatar
To my knowledge, the resistors are required. I used them in my installations. I found it easiest to find the 150 and 478 ohm resistors using a multimeter.
Old Jul 7, 2008 | 08:45 AM
cRaCKwHoRe's Avatar
I also used them on my 03 Sedan and can verify that everything worked properly in doing so.
Old Jul 7, 2008 | 09:08 AM
G35 Mass's Avatar
You DID use the resistors, correct?
CORRECTION TO MY ORIGINAL POST! I AM USING THE PAC SWI-PS, NOT THE PSI-X
Old Jul 7, 2008 | 09:33 AM
cRaCKwHoRe's Avatar
Yes I am using the resistors, and you need to use them regardless if it's a SWI-X or SWI-PS. The install instructions are the same.
Old Jul 7, 2008 | 09:35 AM
cRaCKwHoRe's Avatar
The instructions on PAC's website say the following:
Old Jul 7, 2008 | 01:37 PM
Meatshackle's Avatar
Deep Sea Moderator
I used a resistor for my SWI-ALP.
Old Apr 10, 2009 | 04:44 AM
ypahuboy's Avatar
is it possible to install this unit without tearing the whole dash apart? can all the wires be found under the steering wheel?
Old Apr 10, 2009 | 10:03 PM
TroysG's Avatar
is it possible to swap an engine with the hood closed?
Old Apr 11, 2009 | 12:28 AM
ypahuboy's Avatar
a simple no would've done.... thanks for the answer anyways.
R350k5
Oct 1, 2015 08:41 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
