Oem Shock Sensor alarm
Old Jul 11, 2008 | 09:35 AM
Gee3point5Mhmm's Avatar
Alright I've been to lazy to install this little unit because i got stuck where to hook up the red wire with the fuse and the yellow wire from the dei shock sensor unit. I stripped the wrong wire from the wrong harness in the BCM, it was red and black like the DIY suggested but it was not 12v.
Anyways to those who install these yourselves can you help me out on which harness (black and red wire) to splice. Does it have to be in the BCM? cause i got like two harnesses that measure 12v but its not in the BCM. Thanks in advance.
Mod's please don't move this to electronics becuase it don't get alot of traffic.
Old Jul 11, 2008 | 09:41 AM
SFLG35's Avatar
FGC President
follow my diy in the electrical diy section
the wires you need are at the ignition harness.
Old Jul 11, 2008 | 10:12 AM
yea i'm trying to find this ignition harness.
is it those harneses above the fuses? I really don't wanna strip another wrong wire.
Old Jul 11, 2008 | 10:20 AM
SFLG35's Avatar
FGC President
the ignition harness is not at the bcm
its at the ignition aka where you put your key in.
Old Jul 11, 2008 | 10:25 AM
"take off plastic panels to gain access to the bcm and ingition wires"
i was under the impression it was behind the plastic board, that's why it doesn't make sense. bah thanks i'll check it now
smartin0924
Aug 13, 2015 07:29 PM
JMSABO
Aug 4, 2015 11:58 AM
stay_tuned
Jul 21, 2015 07:09 PM
gabe3d
Audio/Video/Electronics
Jul 19, 2015 05:43 PM
