RBC Install - Ashtray Question
Old Apr 28, 2004 | 07:33 PM
BigmikeOC's Avatar
I'm looking to install the Remote Boost Control for my JL 500/1 amp in my ashtray. I was able to pull out the inner plastic piece of the ashtray with no problem but does anyone know if removal of the entire ashtray is possible without removing the center console? Call me lazy but I've got no other reason to remove the center console so I'd like to leave it well enogugh alone and just snake the wiring for the RBC behind the dash by hand.
Old Apr 29, 2004 | 11:42 AM
Meatshackle's Avatar
Deep Sea Moderator
Re: RBC Install - Ashtray Question
Pop up the silver finisher over the gear shift and it will come right off. The ashtray is attached by 4 screws in the back and some wires for the hazard and the light.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Apr 30, 2004 | 11:06 AM
BigmikeOC's Avatar
Thanks for the tip, I'll give it a shot this weekend.
-=Bigmike
Old Apr 30, 2004 | 05:58 PM
Deep Sea Moderator
Get a small flat tip and pry up on the "rear" end of the silver finisher around the gearshift. This will give you access to the ashtray.
Russ
Black 6MT Coupe
Jax, FL
Old Apr 30, 2004 | 08:20 PM
MyGUnit's Avatar
i have a boost control for my rockford amp...but didn't feel like running the wire.....do these boost controls even do much?
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Nav/TV Tuner w/ PS 2
2-10" Subs w/ Rockford Amp
Clear Corners
Pop Charger
Z-Tube
Old May 1, 2004 | 04:43 PM
bullseye's Avatar
I have a Directed Audio 1300w 5-channel amp, and its boost controller manifests bass levels from virtually none to way too much! If you listen to the same kind of music all the time, you could just set the boost controller where you like it, and leave it in the trunk. If you listen to all kinds of music, you should probably mount the boost controller within easy reach.
'03 G35s 5AT, Garnet Fire/Willow
18" SSR GT1/Bridgestone PP S03
Eibach Springs/Sways, Stillen 2-pc BBK
Stillen SS Cat-Back Dual Exhaust System
Old May 3, 2004 | 07:59 AM
Deep Sea Moderator
No problem man. Glad you got your 27 cents back, lol.
Russ
Black 6MT Coupe
Jax, FL
jsimonk
Dec 22, 2023 03:49 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
