Minimal audio install
Old Aug 1, 2008 | 01:48 PM
finagle69's Avatar
just a quick update:
yesterday while driving home, i noticed when i made a sharp turn that the amp would cut out, then come back on..
when i got home i pulled on the remote on wire and it pulled right out. this being a used amp, the hex screw for the remote on is fairly stripped.. even a torx bit i had wouldn't make it any tighter. this was after stepping the wire up to 16AWG speaker wire via butt-splice.
so i pulled it out, turned on the Signal Sensing and haven't looked back. the amp basically looks for an sound signal on the RCA inputs and powers the amp if it sees it. seems to work just fine.
Old Aug 1, 2008 | 01:53 PM
JCIV's Avatar
Originally Posted by finagle69
Per your request..
You da man, thanks
Old Nov 8, 2008 | 10:03 PM
finagle69's Avatar
updated pics in new thread.
https://g35driver.com/forums/audio-v...ml#post3609233
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
hdmark
Apr 29, 2019 04:31 PM
willdogs
Dec 8, 2015 11:32 AM
Hotdawwgman
Sep 18, 2015 04:19 PM
Cacoepy
Aug 3, 2015 01:09 PM
