lacking midbass from my components
Old Sep 7, 2005 | 08:27 AM
khsonic03's Avatar
This is kind of a rudimentary way, but when I constructed my spacers, I just used some silicone to seal it directly to the door. Makes a 100% air tight seal. It will be a PITA to remove later, but I'm not really concerned right now. I'll probably just tear it out when that point comes around. I have good midbass with my HEX's.
Old Sep 7, 2005 | 10:27 AM
el_duderino's Avatar
Originally Posted by kennyq45
So how do you get a seal around the door speaker? I thought about this too, that's the only difference the bose/boston setup.
Well, I use foam waetherstripping tape from Home Depot, but the seal between the back of the speaker and the spacer or the back of the spacer and the door is not my main concern. I'm worried about the front of the spacer-speaker stack meeting the back of the door panel where the foam tape is around the grille opening.
Old Sep 7, 2005 | 09:54 PM
shooter's Avatar
It's not the critic......
you can remove the window control panel and install the door panel back in place and check the fit..........here is a shot of mine and the speaker/foam is touching perfect!
Old Sep 7, 2005 | 10:50 PM
kennyq45's Avatar
Thanks everyone, I decided to use the bose speaker mount and just fabercated it to fit my boston pro's. I only had time to hook the right side up and it sounded soooooo much better. Thanks for the tips, I can't wait to hook the other speaker tomorrow.
Old Sep 9, 2005 | 12:54 AM
nyckid's Avatar
kennyq45, can you post some pics wit the fabricated bose speaker mount that came with your car, i would like to do the same thing. the damn audio shop did a terrible install, theres gaps all around the 6.5 speaker in my door and i would like to do this myself if i can use the factory speaker mount. will love to see how you did it, please let me know. thanks
Old Sep 9, 2005 | 10:28 AM
opimax's Avatar
I have cut the door panel flat (almost) from the inside, used 2 pieces of wood, either 1.5 or 2 inches total (sorry forgot which) to bring the woofer closer to the door panel. I can't say which way is better but it is a different solution to think of .
Mark
Old Sep 9, 2005 | 10:59 PM
kennyq45's Avatar
nyckid, here are some pics of my moded door pods.
before and after:
Attached Thumbnails lacking midbass from my components-before-boson.jpg   lacking midbass from my components-before2.jpg   lacking midbass from my components-after2.jpg   lacking midbass from my components-after3.jpg   lacking midbass from my components-000_0024.jpg
Old Sep 9, 2005 | 11:04 PM
kennyq45's Avatar
I also used a lot of foam between the door pod and the door and a little between the door pod and the door panel. All I can say is wow what a huge difference! I was disapointed at first with the sound with just the 3/4 mdf mounts I had no midbass but now it almost sounds like a little sub is in the car . Let me know if you have any questions good luck. Oh, I'm getting the doors dynamated on monday so it should sound even better then.
Old Sep 10, 2005 | 12:47 AM
Glad it's working... you now know something most shops don't...
Old Jul 30, 2006 | 05:49 PM
nyckid's Avatar
hey kennyq can you post those pics up again, i havent check this thread in a long time and i guess the pictures are all distorted
would love to see how you fixed the problems, i havent had a chance to fix my boston components 6.5's yet... sigh
Old Nov 9, 2006 | 09:09 PM
Gilley's Avatar
Good advice. So foam weather stripping between the face of the speaker and the back of the door panel should work well enough to get the sound into the cabin?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
