No AC at all, possible leak?
Old Aug 6, 2008 | 03:52 PM
xraycat's Avatar
I just finished replacing my stock HU/HVAC with another stock one and everything is working fine except there is no AC, none at all.
I know that there are problems with the cabin sensor becoming detached and the actual AC harness that connects to the circuitboard having problems but both of those are fine as far as I can tell.
There isn't AC when I turn the temperature all the way down (18 Celcius) so it doesn't seem like those would be a problem anyway. It must be out of refridgerant which would mean there is probably a leak, right?
On the other hand, I don't really understand what is in written in the sticky about the retaining clips on the AC harness. I never had to remove or slide them up when disconnecting or reconnecting the harness, just had to press in the release on the harness and pull it out to disconnect.
Could there be something else I can try?
Old Aug 6, 2008 | 03:55 PM
Hi-TechG35's Avatar
Try to unplug it and plug it back in. Make sure you didnt pinch any wires when reinstalling. That happened to me when I changed my DD. Afterwards everything worked just fine.
Old Aug 6, 2008 | 04:00 PM
xraycat's Avatar
Do you mean unplug and re-plug in the sensor or the harness? I'm pretty sure there isn't anything I can try with the harness behind the stereo, it's definately connected.
Old Aug 6, 2008 | 09:57 PM
jjyellow's Avatar
was it working before the install?
Old Aug 6, 2008 | 10:46 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Fuse??????
doc
Old Aug 7, 2008 | 12:05 PM
xraycat's Avatar
There are two fuses in the driver's side panel but they are for the blower and both are fine.
I am getting it looked at today, hopefully they can figure out what it is.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
vamarris
Sep 26, 2015 12:56 PM
