Question about amp kit plz help
Old Aug 12, 2008 | 11:10 PM
g35coupe253z's Avatar
im using a jl 1000/1 amp and w7 12inch sub is it okay if i use the factory batteries? i know yellow top optimadrive is recommended...and is it okay if i use a 4guage when 0 guage is recommended? ur advice would help thanks
Old Aug 12, 2008 | 11:35 PM
jimrockford's Avatar
The factory battery should be fine.
With 4AWG wire, I'd keep the length as short as possible. At full load (100 amps), you could have as much as an 8% voltage drop with 20 feet of cable. Reducing that to 10 feet would reduce the loss to 4%. With 0AWG, you'll see 1-3% loss depending on length.
However, you're unlikely to pull 100 amps for an extended period of time, if at all. So, actual loss will be lower.
Old Aug 13, 2008 | 02:32 AM
The Stimulation's Avatar
4 gauge as stated is fine. Only thing I can add as running a full wire run from the battery's negative to the amplifier ground rather than a wire grounded from the amp to the chassis. Reason for this is that current follow the path of least resistance. A direct connection to the battery is best as opposed to the chassis since there are paint and other metals which may not be as good of a conductor as the direct battery to amp via wire. Make sure you are using copper wire, not something like aluminum.
Old Aug 13, 2008 | 06:13 AM
thx u guys help so much i was gonna go with 0gauge but i bought 4guage at car toys for $100 that was very stupid of me i couldnt wait thats why but ill buy a 0guage wire eventually..CAR TOYS IS A RIP OFF!!!! sorry for any of u who works there
Old Aug 13, 2008 | 10:14 AM
Ouch, that is a rip off. Check into the Kicker PKD4 (4 gauge kit) on eBay, it's roughly $60. The PKD1 is about $100 on eBay, and that's the 1/0 kit. Good luck with the install!
nettcar
Aug 25, 2024 11:59 PM
hdmark
Apr 29, 2019 04:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
