Weak range on the alarm fob
Old Aug 21, 2008 | 05:18 PM
Ginu's Avatar
Does anyone know a fix for the extremely short distance due to the weak signal for the original fob?
So far I have changed the battery and it works the same and soldered a wire on the antenna thinking it might help with the range.
Unfortunately the fob craps out at around 4 to 6 feet of the car.
It pisses me off when I cant think if i armed the car or not so have to walk back across a road just to check, extremely annoying. Does anyone have any other fixes for this?
Old Aug 21, 2008 | 05:26 PM
SiouxFallsG35's Avatar
A 2nd fob would rule out the possibility that you have a dud. If you don't have a 2nd, borrow one from another nissan/infiniti owner and program your car to it.
Do you have metallic window tint?
Old Aug 21, 2008 | 08:31 PM
Gilley's Avatar
Hold the fob to your chin when using it to gain additional range.
Old Aug 21, 2008 | 08:39 PM
dofu's Avatar
20 Year Member
Could it be the antenna?
Old Aug 22, 2008 | 01:28 PM
Ginu's Avatar
Yes I do have another remote and I did try it... They both have the same range maybe a foot if that in difference.
Is it possible that the receiver antenna in the car might be a little loose or a bad connection?
And the car is tinted with the stock tint that comes with the brilliant silver color, so I don't think that should affect the range.
Drives me up the wall. I guess another fix would be to install a after market alarm but I rather spend the money for something different for now.
Old Aug 22, 2008 | 03:18 PM
By stock tint I assume you only have the very faint greenish tint which allows 98-ish% of light through. Anything other than that was not Nissan factory tint.
Here's the receiver location on the passenger side:
Old Aug 22, 2008 | 03:50 PM
Ginu's Avatar
Ah thats very helpful
I will pluck that unit out and see if there is anything loose and if it will fix the range a little bit i will post what I did.
And you are right it is the factory tint which allows around 96-98% of the light to come in.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
mbe32
Nov 13, 2015 11:09 PM
