It Has Begun... donpisto's '06 G35 Sedan Install
Old Aug 22, 2008 | 02:30 AM
The Stimulation's Avatar
Well, the day has come sooner than expected. This build log will take quite some time since there is so much to do, and a tight budget (I can thank the local government for that ). I don't know if my plans will remain the same since I constantly change my mind, but here is a rundown of what I intend to do.
First, the equipment.
Amps: Zapco 9.0 for the sub and Zapco 4.0 for the mids and tweeters
Mids and tweeters: Zapco CK-16.2 (I won't be using the crossovers sine I will be going active).
Sub: One 15" oldschool JL 15w6
Deadener: Various Second Skin products
Head Unit: Stock.
OEM Integration and processing: Alpine PXE-H650
Battery under hood: Odyssey PC 1200
Wires: Kicker power, ground, and speaker. Symbilink cables made by Megalomaniac. Any RCA's that may be needed I will make myself using Canare coaxial cable and Tara Labs solderless RCA ends.
The idea:
I decided to stick with OEM integration because going with the aftermarket route is too expensive. The double din kit is roughly $250, head unit is about $400 - $800 (Alpine W200 or W505), blue tooth for compatibility is approx $200, steering wheel control is about $75, and there may be some other additional costs. Using the H650, I will only need to spend $310 for it and get a LOC. I will also be able to keep the steering wheel controls and OEM bluetooth.
The sub will be in roughly 1.25 - 2 cu. ft. sealed and wired in series at 12 ohms (no that's not a typo).
Tweeters will go in the A pillars while the mids will be on axis and I will get kick pods. I'm not putting mids in the stock location because even if I get baffles for them, I will more than likely have fitment issues and I am not going to my doors as I did with the Accord.
Sub: I chose the oldschool 15w6 because I have heard a pair of 10w6's back in high school and they have great output for such little power. I want to go with a 15" sub because I haven't seen any G35's with a 15". I would have gone with an 18w6, but it would require a slightly larger enclosure and room capacity is important. I am building this so that the sub is all the way in the back and the amps, I'm not sure where they will be mounted, but I should still have 3/4 of the trunk still available to use. I also got this at a fair deal and considering it's brand new (yes, it has not been used for nearly 11 years), it makes it a bit more special.
I have recently deadened the trunk with a layer of Damplifier Pro and I may add an additional layer. Rear doors will get a layer of Damplifier Pro. The front doors will get two layers of Damplifier Pro and Rattle Pad. Sludge will go on the wheel wells and on the fenders. I might get Motor Mat for the hood along with Firewall Sludge. I may do more, I just have to see what issues arise.
The Goal: To be able to conserve space, have a musical soundstage that blends well, no SPL or loud daily setup. Also the ability to get fairly loud (mid 30's on music around the low 30 Hz area would be nice, but I'm not sure if I would be able to achieve it. If not, oh well. And as mentioned, to get low .
And now, the vehicle. As mentioned, it is a 2006 Infiniti G35 sedan. It has all the bells and whistles minus the sport package, which I don't mind at all. I will be installing Tein Basics coilovers in about a week. Currently I have 20" MOZ Tower 5 rims, but I am selling them and going with stock 17's, but I will go back to 19's, maybe 20's. The Infiniti letter in the back has been debadged and the Mt. Fuji emblem along with the G35 emblem will be a black chrome.
I also plan to get overlays for the tail lights and the roof. I will get the head lights blacked out and also get clear corners and smoke them. I have a couple mods to the car currently, nothing major, just a 5/16" Motordyne Intake Manifold Spacer, Z tube, Pop Charger, Coupe Midpipe, and HKS rear section muffler. I might go with a turbo kit in the future, but that won't be years down the line.
Enough talk, time for pics of the vehicle.
With stock rims:
With the current MOZ rims:
One layer of Second Skin Damplifier Pro on the trunk lid:
Before:
After:
I was able to do the inner portion of the trunk lid and I'm sure it will help reduce vibration by alot. It made it easier to take out the tail lights and the trunk latch.
I also did the license plate. I'll be adding Rattle Pad once I find where I have my leftover pieces.
It definitely passed the knocking test . Here is a before video without deadener:
and here is the after video with one layer of deadener
. I will probably add another layer of Damplifier Pro and I'll see if I have to do more than that once the setup is complete.
Old Aug 22, 2008 | 02:33 AM
scarface_613's Avatar
GL with everything
Old Aug 22, 2008 | 03:38 AM
16psibrick's Avatar
looking good, i see you have decided to more forward hehe
if oyu need any help feel free to hit me up
good luck!
b
Old Aug 22, 2008 | 03:42 AM
Yeah, I figured by winning the Bulk Pack of Damp Pro I might as well get started. Hopefully I'll have success with the H650. I figure npdang is using it and seems to find it okay so it should be fine. Worst comes to worst I'll go the complete aftermarket route.
Originally Posted by scarface_613
GL with everything
Thanks!
Old Aug 22, 2008 | 03:43 AM
16psibrick's Avatar
keep me updated, next time i am down there, i wanna check it out...
i have tried all sorts of factory eq/oem interface on the stock G/Z bose HU, and all sounds a bit weird to me hehe
b
Old Aug 22, 2008 | 03:47 AM
Will definitely do, but this build will take quite some time. Once I get transitioned to a full time employee it will move along much faster. Trying to save up for my own place is also another thing on my plate.
Old Aug 22, 2008 | 04:00 AM
bmpnride's Avatar
That deadener looks pretty good. One layer was really effective on the trunk lid. Nice..
Old Aug 22, 2008 | 04:23 AM
astonv12's Avatar
very cool I like the before and after videos. Keep us updated. Holy crap lol @ the Accord trunk in your 18"TC video.
Old Aug 22, 2008 | 05:12 AM
GooberGman's Avatar
Why run rubber on those wheels at all.......gotta feel like a horse & buggy.
Old Aug 22, 2008 | 10:00 AM
That was nothing actually, it was only getting 1,000w (single PDX 1.1000). I was going to have 4 PDX 1.1000's on it, but then I got into an accident and car was totalled. Before the single PDX 1.1000 with that box (2.4 cubes sealed), I had it in 5 cubes sealed and off 3,000w. It was solid ear sex. It got pretty loud, but more importantly it sounded real smooth and got stupidly low. With a 14 Hz note, the front windows moved a good inch or so. I'm surprised it never fell out of its mounting or bracket, lol.
Old Aug 23, 2008 | 03:53 PM
It has arrived... my 15w6 BNIB. It's sexier than I remember.
Free air vid:
Old Aug 23, 2008 | 04:06 PM
manbeer's Avatar
good stuff, can't wait for the finished product. great choices on the equipment and very unique compared to what you typically see in these cars. i love the NOS w6 and at 12 ohms, i wonder what the 9.0 will do, i though the power suply was pretty tightly regulated so i'm wondering the outcome. I had a handful of old style w6's when they first came out, back in high school they were the hottest thing out. very impressed by the damplifier as well, one layer seemed to make a huge difference. keep us posted!
Old Aug 23, 2008 | 04:15 PM
Will definitely keep everyone informed. The reason why I did get the OS W6 was because as you said in high school they were the hottest thing. I had heard a pair of 10's in an El Camino off about 600w and they got loud. Also had a friend with an Expedition who had 3 10" W3's off 1,000w, maybe less and those got pretty loud too.
It was either 15w6 or an Aura NS-15. I'd love to run the Aura, but it is a bit pricey. If for any reason I'm not satisfied with the 15w6, I might end up buying the Aura, but I think I will be satisfied. The 15 does look somewhat tiny to me, I was used to running an 18 in my Accord.
Old Aug 23, 2008 | 08:21 PM
Gilley's Avatar
Looks like a really nice project. Good luck with it.
