Need Serious help guys - 12V Switched power under the car?
Old Sep 20, 2008 | 09:40 AM
elrooko's Avatar
So I'm installing exhaust controllers under the car in the exhaust and I want 12V switched power under the car. What wire should I tap? Should I tap it at the fuse panel and bring it outside somehow? How can I bring it outside the firewall?
Can someone help me out?
Old Sep 22, 2008 | 08:46 AM
elrooko's Avatar
Bump - anyone?
Old Sep 22, 2008 | 09:45 AM
Gilley's Avatar
Tap the fuse panel and run the wire through the firewall through one of the rubber grommets. There is a big one behind the battery. Just be sure to seal it with silicone.
Old Sep 22, 2008 | 10:01 AM
elrooko's Avatar
Do you know which wire at the fuse panel to tap? I tried searching and came up with nothing.
Old Sep 22, 2008 | 02:19 PM
Gilley's Avatar
There are a lot of switched fuses at the fuse panel by the driver's feet. Use an add a circuit so you won't have to cut any wires.
chinee
Jun 10, 2024 07:48 PM
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Frostbite91
Jul 27, 2015 05:25 AM
BlackGee35
Jul 21, 2015 07:24 PM
