Installed Kenwood DNX8120
Old Sep 22, 2008 | 11:55 PM
slvrg05's Avatar
I am using a hub to connect a flash drive. I'm not sure if wut ur asking will work with the unit.
Old Sep 23, 2008 | 08:03 AM
blazeplacid's Avatar
as long as the USB device draws less than 500mA of current it will work
I belive that 250gb draws 1amp and will not work
I think you have to find a 1.8" harddrive
Old Sep 23, 2008 | 07:14 PM
bL1Z's Avatar
Looks really nice man. good job.
just an fyi - ultimate electronics quoted me $400 minimum install for this unit if I brought all parts to them. I'm kind of curious how much other people have paid for a "professional" install.
How many hours did you and your friend spend on it? Was this your first install or did you just wing it?
Old Sep 23, 2008 | 08:29 PM
slvrg05's Avatar
i took more time than usual because i did not want to use any tools that might damage the aluminum console so I use my fingers and wood strips to pry up the shifter trim. I've done several installs on previous cars i had so I knew what to connect and. i just took my time in getting everything in the way I wanted an ultimately came out perfect.
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
