Mounting Depth
Old Sep 21, 2008 | 03:32 PM
JayJay's Avatar
Mounting Depth
I Have an 07 sedan with bose, which means that there is an 10" speaker in the door. I plan on doing the whole system over, and would like to know
Does anyone know the mounting depth for the front speakers?
Old Sep 22, 2008 | 09:59 PM
iron chariots's Avatar
tweet: 1 3/8" diameter, 5/8" depth
mid: 3 1/4" diameter, 1 7/8" depth
door woofer: 10" diameter, 2 3/8" depth
i didn't replace the center channel or the rear door speakers so i don't know what size they are.
Old Sep 22, 2008 | 10:33 PM
Boostwhore's Avatar
just hope you werent thinking about trying to put a 10 in the door. I would convert the hole to a 6.5 and then put a single 10 in the trunk
Old Sep 23, 2008 | 01:42 PM
The Stimulation's Avatar
What's wrong with 10's in the door? I plan on putting 10's in my '06 sedan. Intense midbass FTW
Old Sep 23, 2008 | 04:23 PM
str8dum1's Avatar
what 10" midbass do you plan to use? midbass is 80 to ~400 hz, good luck finding one that sounds good in that range.
Old Sep 23, 2008 | 04:29 PM
Peerless SLS 10" (http://www.madisound.com/catalog/pro...oducts_id=1705)
Plays just fine down to 56 Hz (and even lower if you wish), use it in a 3 way setup and use it from say 56 - 350 and have the midrange pick up at 350 Hz. It is 8 ohms, but the driver is VERY efficient and does not need much power and it sounds great.
I've also heard a couple different Seas drivers that have some intense kick to them.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Claudiu
Sep 26, 2015 01:04 PM
Claudiu
Sep 24, 2015 01:12 PM
