Installing subs/amp, HELP!
Old Sep 21, 2008 | 09:14 PM
MM_G3520's Avatar
Hey guys,
I just picked up 2 12" Type-R's, a type-1 box, and a Sony 1200 watt amp. I will be doing the installation myself, and I was hoping for some tips.
1) The previous owner of the box/subs wired them in series. What do I need to do to make sure that everything works as it should?
2) I do NOT have a Bose system. How does that change the complexity of the installation? For those that are not familiar, a non-Bose system has 4 door speakers and two small tweeters (I think that's what they are) by the side mirrors. I have no factory amp.
3) Can someone run me through the sequence of what to do behind the headunit? Do I even need to remove the headunit (I'm assume so)?
4) My friend recommended that I use a line out converter, but in another thread I received advice that this is not necessary for G35's. Can anyone shed some more light on this becasue that quote was based off of the assumption that I had a Bose system.
Thanks for the help, and go easy on me. This is my first foray into the audio world.
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
