Opinions on this Subox....using 2 JL Audio 10w6v2
Opinions on this Subox....using 2 JL Audio 10w3
I wanted to get your opinions on this box...
I MEANT TO PUT 10w3 in the box.
- will fit 2 10" subs
- hole cutout is 9 1/8 "
- mounting depth is 8"
- internal airspace is 1.70f^3, mono chamber
- gold-plated terminals (which also accept banana plugs)
- professional paint in ANY color you want. We just need the paint code or color name.
- thick black or charcoal carpet on the back. (your choice)
- raised "infiniti" logo molded into the fiberglass
Not installed:
Installed:
Not installed:
Installed:
my last question is... they offer this as well if I wanted...
Add a center divider making each chamber 0.8 f^3
Would that be better?
here are the dimensions on the subs
Continuous Power Handling: 300 Watts
Coil Resistance: 4 ohm
Xmax (one-way, linear): 0.550 in. / 14.0 mm
Driver Displacement: 0.049 cu. ft. / 1.39 liters
DC Resistance: 7.240 ohm
Efficiency (1W/1m): 85.22 dB SPL
Mount Depth: 5.93 in. / 151 mm
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
FS[SoCal]: D/S 4080 Enclosure & JL Audio W6v2 10 inch
MrIP35
Nov 8, 2015 10:47 AM
