Speaker Level Amplifier Question..
Old Sep 25, 2008 | 03:52 PM
ricerocketdave's Avatar
This is for a 2004 coupe equipped with Bose...
I am going to be using two of THESE amps in my car..
Should I use a PAC adapter or can I just get away with using THESE
I have been searching around and there is a lot of mis information about this topic. I want to get my facts straight before I do this..
I have been into car audio for a long time but this is my first attempt at integrating equipment into a factory system.
Old Sep 26, 2008 | 08:12 AM
Gilley's Avatar
The Bose HU outputs line level which you can send straight into your PP amps with a cut RCA cable. The sticky threads will tell you what color the wires are that you need to tap before the Bose amp.
Old Sep 26, 2008 | 09:00 AM
Thats what I was thinking.. I just needed to verify.
Now another question arises.. What is the voltage of that line level?
Thanks!
Old Sep 26, 2008 | 12:28 PM
Gilley's Avatar
From what I have read, the Bose HU voltage is less than 2 volts.
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
mbe32
Nov 13, 2015 11:09 PM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
master111
Sep 25, 2015 08:32 PM
