Boston Acoutics G5 Subs
Old Oct 15, 2008 | 11:03 AM
35bills's Avatar
Anyone running these in your cars?
What are your opinions about them? I need some feedback!!!!!
Looking at the 10" sub BTW....
Old Oct 15, 2008 | 06:58 PM
The Stimulation's Avatar
I heard a pair in a Magnum a couple years back and they sounded pretty good. What type of sound are you trying to obtain?
Old Oct 15, 2008 | 10:49 PM
35bills's Avatar
I am looking for SQ...something that hits tight...not boomy.
I'm running an Audison Srx 5. I was looking at getting a 10" G5 with the dual voice coil and run it at 2ohms from the amp(roughly 280W to 300W).
The fronts and rear fill, I'll run at 4ohms...about 50W per channel X4.
Maybe put it into a 4080 box???
Old Oct 15, 2008 | 11:50 PM
darrick's Avatar
Im pretty happy with mine
Old Oct 16, 2008 | 12:05 AM
SQ wise i'd say the sub should be good. It's get pretty good output.
Old Oct 16, 2008 | 06:29 AM
35bills's Avatar
i was just looking at the amps specs...I'm not sure if the amp is stable down to 2ohms. According to the paper it's not but its not written clearly.
The newest version(2008) is stable into 2 ohms...
Old Oct 16, 2008 | 10:51 AM
Call or e-mail Boston Acoustics. They are really good with their customer/tech support.
Old Oct 16, 2008 | 10:56 AM
35bills's Avatar
Just found out that my amp is 4 ohms at the sub only.
Maybe should I go with a seperate amp for the sub and leave the Audison running as a 4 channel? I really love this amp..its very clean sounding.
Is that a possibility?
I think it would open up more options for me.
Old Oct 16, 2008 | 11:12 AM
Wait, you said your sub is dual 2 right? And amp is 4 ohms? If that's the case, you're fine. You can use it, because you have to wire the two coils together and you can do it either in parallel at 1 ohm, or in series at 4 ohms. Here is a wiring diagram.
http://www.rockfordfosgate.com/rftec...1&woofer_imp=3
Old Oct 16, 2008 | 11:33 AM
35bills's Avatar
I totally understand that part but the amp only pushes 180W to the sub(RMS). Wouldn't be a bit underpowered running at 4ohms?
Thats why I wanted to see if I could run a 2ohm sub...the amp would be more efficient that way.
..and yes the sub would be a dual voice coil for more flexability further down the line.
http://mobile.bostonacoustics.com/newproduct/G5_lit.pdf
they use fuses to change the impedance...
amueller633
Mar 29, 2011 09:22 AM
konigz021
Aug 15, 2010 04:25 AM
xxjustimajinxx
2nd Gen (V36) Sedan
Jun 19, 2010 12:05 PM
Hi-TechG35
Archived Sales
14
Apr 13, 2007 10:38 AM
