double-din HU question
Old Oct 18, 2008 | 05:17 PM
Heist.'s Avatar
I can't find anything about if people had to install the Metra OEM Adapter to put a dvd 7" new HU or if they just cut away the plastic in the way. I have been getting errors with my stock HU on my 03 g35 sedan. So I was going to get a JVC KW-AVX710. If anyone has done this please help me out!
Old Oct 18, 2008 | 10:16 PM
SmoothieG35's Avatar
Yes you cut the middle plastic bar if you are going DD instead of single din.
Old Oct 19, 2008 | 03:25 PM
Telly9987's Avatar
i just installed a zvic z3 i just cut the plastic support bar that seperated the dins. literaly a 45 mins install
Old Oct 19, 2008 | 05:47 PM
Heist.'s Avatar
Ok perfect going to order it today then thanks for the help.
Old Oct 20, 2008 | 03:35 PM
blazeplacid's Avatar
heads up:
if you plug everything in but your ac doesnt do anything as in temp up down/ mode button doenst work, you may have to remove the platic backing on the metra kit and make sure there are no jumpers
that had me stumped till I called metra
Old Oct 21, 2008 | 12:12 AM
Heist.'s Avatar
Originally Posted by blazeplacid
heads up:
Ok thanks. I was worried about running into something like that I always seem too.
Old Oct 24, 2008 | 08:07 PM
Heist.'s Avatar
Wish someone would of dropped the hint that it dose not work on an 03. woahhh 300$ for a conversion kit.
Old Oct 25, 2008 | 10:01 AM
Bigrose's Avatar
^ ???? Conversion kit?? For what, the wiring harness??? I have read lots about this and this is the first I've heard...
Old Oct 25, 2008 | 08:32 PM
Heist.'s Avatar
JDM AC controller just found that out in the sticky right after it got delivered. Very sad.
Old Oct 27, 2008 | 12:19 AM
zrose27's Avatar
does this also work on the 2003 bose units? sorry if noob question
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
