JUst some sub/amp questions on installation
Old Oct 30, 2008 | 03:31 PM
crazeejitt's Avatar
Okay just correct me if I am wrong or if I am missing anything. I have a sub and and an amp and a wiring kit.
1. I connect the red power cable from the battery to the amp.
2. I connect the black ground cable from the amp to the g35's chassis (making sure there is no paint in the way.
3.(part I am making sure of) I connect the blue remote cord from the amp to another blue cord that is going the the stock amp.
4. I connect the RCA cable from the amp to the sub.
Please tell me it is that simple.I think I got it I am just not sure on the remote wire part. I cut the outside part off of the stock amp remote cord and wrap the new amp around it correct?
Old Oct 30, 2008 | 06:44 PM
MikeGrote's Avatar
the stock rem wire is light blue/silver. and you dont have to strip that wire, there are some splice connectors that make it really easy and you dont have to strip that wire at all
make sure you put an inline fuse on the power wire as close to the battery as you can
Old Oct 30, 2008 | 07:15 PM
Xet's Avatar
Xet
rcas dont go from amp to sub. you either have to do the like the diy guide if you have a bose amp and splice those signals, or get a special kit/connector to create preouts from your stock headunit, or get an aftermarket headunit with built in preouts.
then you connect speaker wire from your amp to sub.
Old Oct 30, 2008 | 07:17 PM
MikeGrote's Avatar
oops, yea i missed that. rcas go from your stock wiring to your amp
Old Oct 30, 2008 | 11:00 PM
crazeejitt's Avatar
my bad I got that mixed up.... but I thought u could splice the RCA's and connect them to the amp.
Old Oct 31, 2008 | 01:46 AM
Xet's Avatar
Xet
yes you can, follow the diy at the top of this forum
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Thunderaan
Jul 22, 2015 07:40 PM
