(1) JL Audio 10w6v2 OR (2) JL Audio 10w3v3
Old Nov 14, 2008 | 04:56 PM
pattyskin's Avatar
Originally Posted by Kidd1077
that box is for the coupe. i was just showing what it loooks like. the box im getting (for the sedan) has .80 cubic inches of airspace per chamber... the w6 and the w3 both call for .65 cubic inches. so its actually .15 cubic inches too much!
You could glue some foam inside the box to reduce the airspace if you want to do it perfectly matched to size.
Old Nov 15, 2008 | 02:47 AM
Kidd1077's Avatar
nah, it will be a little less punchy and a little bit more "smooth"... lol i couldnt think of a better word than smooth, but thats not the best word to use.
Old Nov 15, 2008 | 09:17 AM
TroysG's Avatar
Well I'm going to provide a lil rain on the W6 party... I too have a 10W6V2 but for the guys saying it'll take a lot more power than rated... COMPLETELY wrong. I'm on my second sub and I'm an installer. I have a Kenwood 8019 (5volt preout) and a Focal 1.800 powering it. I have my gain at a quarter, my xover on the amp set between 60 and 80Hz and my deck set to +2 for the sub (xover 80hz). and I torn the foam surround on my first one. IF the surround was rubber FANTASTIC sub but the foam surround will give you a warmer feel to your bass.
But to those people who claim the W6 can take more than 600W... DEFINITELY not. They also may be running lesser amps. Or they could be running better amps without knowing their setups I can't say.
Old Nov 15, 2008 | 11:47 AM
The Stimulation's Avatar
Well there's your problem. You're running Focal amps. Just a guess, but that amp is more than likely quite underrated. I used to have a friend that had 750w going to his on a Kicker amp and those tend to do a little more than rated power but not much, it all depends. The sub can take a little more than 600w, but the thing is, it's not needed since they are pretty efficient drivers.
Old Nov 15, 2008 | 12:05 PM
Deftronix's Avatar
Originally Posted by CLiX`G35
i have two 10w6 in 4080s hooked up to a 1000/1 and its more base then your car can handle without being heavily dynomatted, i usually leave the base **** only half way,
that said they can take the 1000 watts easy i wouldn't try it on just one 10w6 when i first installed the amp i tested with one and i wouldn't dare take it all the way seemed like the little guy wanted to rip itself apart, and i did volt meter set my amp so the gains weren't messed up at the time.
as far as sound I have notice in certian songs ... one mic comes to mind there are lows you cant hear only feel so they go low, i tested it with a 20 hz tone and they handled it well... my experience is pretty limited when testing subs but these i like a lot.
EDIT** I mentioned NAS One Mic while it deos have effects and gets really low its not too loud i meant the beginning of got yourself a gun.
You wire it in parallel or series?
Old Nov 30, 2008 | 07:50 PM
Kidd1077's Avatar
hey quick question for some of you again... this isnt for me, it for my friend. he listens to pretty much rap and rap only.. hes more for how hard the setup hits over the quality of the setup. anyways, he was considering doing 2 jl 12w6v2's each with a 500/1 amp or one jl 12w7 with a 1000/1.... which would you say would hit harder and which would you prefer? btw, he drives a f150.
Old Nov 30, 2008 | 08:01 PM
lilindienplaya's Avatar
2 w3's will probably be more eficiant in the enclosure you plan on getting the W6 need volume and that small box wont help.
Old Nov 30, 2008 | 08:30 PM
Kidd1077's Avatar
haha the w3 and the w6 call for the same airspace... the encloure im getting already has more airspace than what the sub itself calls for. ive already decided im going with the w6... check two posts up from here on what i asked, please... thanks
Old Nov 30, 2008 | 08:31 PM
what enclosure are you using? iwould like to get one if it can house a W6 nice
Old Nov 30, 2008 | 08:47 PM
Kidd1077's Avatar
i dont have anything yet.... gotta wait til christmas. and for the box im doing zenclosures (off ebay) 10" offset with the whole to the left and the amp placement to the right. it has .80 airspace, and the 10 w6 calls for .625... i believe thoes numbers are right.
Old Nov 30, 2008 | 11:49 PM
TroysG's Avatar
As for your friend. he'd prolly wanna go 12", multiple sub, big power, I'd point him towards W3s... the W7 foam surround = CRAP for max excursion, and lotsa power. I've seen FAR too many W7s coming back lately with abuse issues. broken voicecoils, torn surrounds etc.
Old Dec 1, 2008 | 09:55 PM
Kidd1077's Avatar
if he doesnt do the 12w7, he wants to do two 12w6's..... hes not interested in w3's.
Old Dec 1, 2008 | 10:23 PM
TroysG's Avatar
if he's going to drop that much cash on subs tell him to go with Image Dynamics the IDMAX it's a SICK sub. About the same price better for high output system.
Old Dec 1, 2008 | 11:50 PM
Kidd1077's Avatar
thanks for the advice, ill look into that for him...
Old Dec 2, 2008 | 09:05 AM
  #30
is there any box that will house a 12W6, i already have one so theres no point in buying a new one.
