Sub and amp w/ stock receiver
Old May 30, 2004 | 08:29 PM
scottkusf's Avatar
I just want to put in one subwoofer and an amp. Can this be done easily with the stock receiver. I just want an easy install without having to mess up my dash.
2004 6MT Coupe Graphite/Graphite / Performance / Premium / Sirius / Navigation / Clear Bra / Aero / Trunk Mat / Splash
Old May 31, 2004 | 12:46 AM
kroams's Avatar
Re: Sub and amp w/ stock receiver
That is not a problem. Either get an amp that you can directly connect using the high's off the rear speakers or get a line converter (LOC). The only tricky part is getting power to the amp (will require some work).
2003 G35c/5AT/BS-Graphite/Prem/Aero/Splash/NISMO sway bars/JWT Popcharger/Z-Tube
Old May 31, 2004 | 04:28 PM
djrobx's Avatar
From your sig it says you have premium. Makes the whole thing super simple. You can tap into the lines going into the Bose amp that's already in the trunk. You will just need to run a power cable from the battery back there.
Since you're adding a sub, I recommend replacing the Bose amp though. Most aftermarket amps have a "high pass filter" (crossover) option which removes the subwoofer frequencies going out to the rest of the speakers. The factory speakers (or any other speakers for that matter) will sound much better and get much louder if they're not trying to do the work that your sub is already doing.
Old May 31, 2004 | 11:38 PM
scottkusf's Avatar
Cool guys, thanks for the help
Old Jun 1, 2004 | 12:13 AM
RamboRami's Avatar
G35driver.com Moderator
too bad you dont have an EQ in that formula... it makes a huge difference, whether its in the HU or not
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
zoop425
Mar 29, 2016 05:51 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Frostbite91
Aug 2, 2015 04:59 PM
Thunderaan
Jul 22, 2015 07:40 PM
