How To Install A Sub In A G sedan Using Stock Bose System
#91
Answered in other thread, but for reference:
Your F700BT (or, really any aftermarket headunit) doesn't output a differential-balanced signal, so the bose amp sees half the audio signal as audio, and the other half as noise that needs to be canceled out.
Installing an aftermarket amp will correct this problem.
#92
Hi all,
I'm trying to install aftermarket speakers and an amp with the stock bose headunit on a G35 coupe.
so far we have replaced the rear 6*9 speakers, the door woofers and tweeters. we left the stock speakers for the rear passengers in.
We installed the amp and got the ground, 12V and remote turnon wires installed and works like a charm. we were looking at the speaker wire pairs that come to the factory bose amp and took out 4 strands of 2 wire pairs.
1. Front Left
2. Front Right
3. Rear Left
3. Rear Right
We connected these wire pairs to the aftermarket amp.
now it's time to get the signal to the aftermarket amp but it has RCA plugs so we got 2 x 2channel LOCs.
to what wires do i connect the LOCs to give the aftermarket amp a signal?
1. Front Left
2. Front Right
3. Rear Left
3. Rear Right
#94
I have a g35x with all my speaker wires hanging in my trunk when I bought the car. I hooked up a rockford fosgate 2 channel 400w amp, along with 2 kicker L's. Everything is hooked up to my stock deck. When I try and play a cd, the cd skips, but when the subs arent hooked up, the cd doesnt, what is causing the skipping and how can I fix it
#96
https://g35driver.com/forums/audio-v...rams-pics.html
#97
anyone hook subs up to the bose headunit and then put in an aftermarket deck with 2v preouts? how did they sound in comparison? am i wasting my time creating a low quality thump by putting in an LOC because its easier? ive got a KAC-9104D, 2 KFC-XW1022D in non ported box. im happy enough with the speakers in the bose system for now, but ive got a DDX512 also out of my old car, is the difference in sound quality worth the extra time, money and modifying a JDM double din to make it fit? 05 sedan w/ nav
#99
#100
ok so im trying to install an amp and sub in my 03 sedan. i followed all the instructions and seem to barely be getting any sound out of my sub, even with all the settings on the amp turned up and the LOC as well. the fan on my amp is on so im pretty sure its getting power. any suggestions????
#103
so far i have run the power wire and connected it to the battery, made the ground to the back of the seat, sanded it down and screwed it in, bought a PAC LOC, twisted the soild wires together and connected to the white wire from the factory sub, twisted the stripped wires together and connected to the black wire from the factory sub,spliced my remote wire into the green n white stripe wire and connected to the amp, connected my RCA wires, and the sub to the amp. ive turned all the settings, gain, x-over, bass boost, ect. all the way up, and i get very little sound out of the sub, i know im getting something because i can feel the sub moving but barely, kinda like how the factory sub worked
#105
