Post pics of your double din setup
#181
I just installed the Metra DD kit with a jensen 7" and I am having a problem with the reception on my radio stations.
No Am stations what so ever (no ESPN RADIO![Mad](https://g35driver.com/forums/images/smilies/mad.gif)
) and a few of my Fm station are no longer working. Is there any way I can fix this?
and also I can no longer use my steering wheel controls. how can I get them to work with my new HU?
thanks in advance and I will post a pic soon.
Not too sure about the radio issues... Did you use a nissan radio antanne adapter?
#182
I had the same problem with the radio in my 350Z when I put in an DD headunit and what it turned out to be is Nissan used a amplifier for the antenna and I had to connect the power antenna wire from the head unit to the amplifier for the antenna, so it would turn on. Don't know if they use the same setup in the G, but I would bet they do. See if you can get the wring diagram for the audio system it should show what color wire it is. Hope this helps
#186
#189
opinions of this headunit? im thinking thats the one, but i am always open to opinions of more knowledgeable audio guys
http://www.crutchfield.com/p_130P330...H-P3300BT.html
