factory deck as hub for system
Old Jun 3, 2004 | 02:33 PM
dagg's Avatar
is it possible to use the factory bose deck for my stereo needs!?!? i would like to add an amp n subs to my system...do i need to cut/splice a rear speaker or something? has this been covered in another thread? if so many someone could point me to it!?!? thanx!
dot com
Old Jun 3, 2004 | 02:48 PM
g35john's Avatar
Re: factory deck as hub for system
You can take a look at my rescent threads about the subject. But that info your looking for its ALL over this forum. FAQ has some good stuff too. Good luck.
"Dont start none, Wont be none"
Old Jun 3, 2004 | 04:18 PM
djrobx's Avatar
Yes. I've done that with mine and am very happy with it.
nycg35 has a great writeup on this subject
<a href="https://g35driver.com/forums/showflat.php?Cat=&Board=AudioVideo&Number=234842&p age=0&view=collapsed&sb=5&part=all">https://g35driver.com/forums/showfla...&sb=5&part=all</a>
Old Jun 3, 2004 | 09:56 PM
dagg's Avatar
thanx djrob!!! basically ill be splicing into a speaker wire!?!?! no cleaner way to do it? sounds like a party!
dot com
Old Jun 3, 2004 | 10:39 PM
bun84067's Avatar
You'll be taking the speaker-level signals coming from the stock head unit and running them into an amp or amps.
Everyone's doing it.
Join the gang.
I'm thrilled with my system, and I kept the stock HU.
Do you have the premium or standard sound system?
Old Jun 4, 2004 | 10:20 AM
RamboRami's Avatar
G35driver.com Moderator
i would run them to a pre-amp EQ...then to your new amp...you'll hear a WORLD of difference.
The stock headunit has no EQ adjustments
On my pioneer HU, you will hear a HUGE difference between "Flat/Standard" mode and my custom-tuned EQ setting... you wont believe your ears.
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din<P ID="edit"><FONT class="small"><EM>Edited by ramborami on 06/04/04 07:21 AM.</EM></FONT></P>
Old Jun 4, 2004 | 02:15 PM
dagg's Avatar
well dang alrighty then!! well i found my subs and amp...not sure exactly which ones are them, but they can be found at this site
http://www.edesignaudio.com/ep2/products.htm
althought im using 2 12's and i think a 800W amp, here is the map for my box dimensions as well...er at least one box...
any suggestions for my EQ? any suggestions for my trunk setup?!?! i saw one system facing right into the rear of the vechile... does anyone on G35driver make boxes? i had a kick *** system in my last car, but i didnt carpet the box or anything, looked like sh*t
http://www.edesignaudio.com/im/main/12SEALED.jpg
dot com
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
5150DS
Sep 26, 2015 07:47 PM
saywat?
Sep 22, 2015 05:42 PM
gatorglaze
Sep 19, 2015 12:06 PM
NJ6MT
Sep 10, 2015 08:40 AM
