Electrical issue please help !!
Old Dec 10, 2008 | 06:21 PM
mmooney84's Avatar
I was working on my power door lock on the drivers side. Replacing with a new actuator. Now My power door lock switch doesnt work and my passenger window doesnt go up or down? But my drivers window still works?
It there a fuse or relay that might of blown out??
Please help
Old Dec 13, 2008 | 05:32 PM
digitalhifinet's Avatar
Check the fuses first. They should be in the driver side kick panel, or under the hood near the battery. If that doesn't work open the door back up and double check that you connected the wire harnesses securely. If none of the that worked, you probably managed to burn out the lock/window control board. You'll probably have to buy a new one. Free plug for Riverside Infiniti.
Good luck!
magnetism80
Feb 1, 2019 10:00 AM
cmesidewayz
Sep 29, 2015 09:28 PM
UT G35
Sep 3, 2015 03:58 PM
Tyler's03G
Aug 13, 2015 10:04 AM
