IPOD : Cassette Adapter or FM Tuner?
Old Dec 16, 2008 | 04:00 PM
interrupt's Avatar
Which would you prefer? So far i've been using a cassette adapter and it's been squeaking for a while, thinking about turning to a FM Tuner, what are the pro's and con's of both? Are the audio quality the same?
Old Dec 16, 2008 | 04:10 PM
acr's Avatar
acr
none of the above... USA Spec iPod adapter is the way to go.
Old Dec 16, 2008 | 04:13 PM
interrupt's Avatar
interesting, never heard of it before. Looks like i'll give it a try.
Old Dec 16, 2008 | 04:14 PM
interrupt's Avatar
hmm, well not so sweet after all, checked out the compatibility PDF and my 03' isn't mentioned
Old Dec 16, 2008 | 06:07 PM
1sexyG's Avatar
http://www.g35parts.com/9083/osc/pro...38a09ac876f3d6
order that. its the factory ipod integration unit from everythingg35.com. If your car is prewired then you just need to purchase and install this unit. Although you said you have an 03 model so I presume that you arent prewired for SAT....in that case, you need to purcahse the prewire harness as well. This unit will allow you to play your ipod through your stock HU. Search more in the audio/video section about it.... you'll learn a lot.
Old Dec 16, 2008 | 07:39 PM
interrupt's Avatar
"Will this work with all model G35's?
– No, this model does not work with early 2003 G35 Sedans (production date before 09/02) as they are not satellite capable and 2007+ G35 Sedans that are equipped with Navigation and XM's Navtraffic."
I think I have a early model G35... how do I check to see the date of production on my car?
Old Dec 17, 2008 | 02:54 PM
fishhouse's Avatar
with a stock headunit you have 5 options:
1. Cassette tape adapter
2. FM transmitter
3. PAC (AAI-NIS2)
4. USA Spec (PAII-NIS)
5. Nissan iPod Interface Kit
i seperated the first two since they are worthless IMO. you need to go with something from #3-#5.
of those, they each have their distinct pros/cons, features and price. you'll have to do the research and decide which works best for you.
this is a VERY common question around here - and i recently had the same question a month or so ago when i was in your same situation and looking for a way to connect my iPod/iPhone to my 07 Coupe.
check out my site myG35mods.com for an Auxiliary Input Adapter Comparison Chart that highlights the specs of all of them to help with your decision.
let me know if you have any questions...good luck.
Old Dec 17, 2008 | 02:56 PM
interrupt's Avatar
thanks for the help, but the problem is that i'm stuck with an early 03' w/o SAT and none of them are compatible with it.
Old Dec 17, 2008 | 03:01 PM
interrupt's Avatar
I have a question though, can I swap the 03' bose headunit with an 04' and hookup an AUX adapter? Will the headunits fit perfectly?
Old Dec 17, 2008 | 03:02 PM
fishhouse's Avatar
you sure you're before 9/02?
Old Dec 17, 2008 | 03:03 PM
fishhouse's Avatar
i would assume so. can you get an 04 for free or something? if you're going to go to any expense you might as well do a DD
Old Dec 17, 2008 | 03:05 PM
interrupt's Avatar
yeah, I just checked my car, it's an 08/02. What's a DD? sorry i'm new to the board and don't understand most abbreviations.
Old Dec 17, 2008 | 03:14 PM
fishhouse's Avatar
8/02...hmm that blows.
no worries, DD = Double DIN...a new headunit to replace your stock one. for example. could even do one with navigation. many have iPod connections built in. if you're willing to spend money this might be your best solution.
i'm on a stock Bose personally so i can't speak for which is best - but i'm sure many guys here could offer some input on good option/brands.
Old Dec 17, 2008 | 10:19 PM
interrupt's Avatar
i'm about to replace it with an 04' Bose Head unit and hook it up with the AUX adapter, will all the steering wheel controls work fine with it? Does anyone else know if it will fit perfect?
Old Dec 18, 2008 | 05:38 AM
on3nonlyjimmy's Avatar
to answer this cassette adapter ftw because if you think about people who are using FM transmitter are also using the same station beside you so you will hear alot of frequency and lose frequency when your under a bridge or tunnel where instead you can go having straight wire and listen directly to your mp3 =] nuff said
