Garmin Nuvi 760 Install with pics
Old Jan 13, 2009 | 01:29 PM
broke_as_ajoke's Avatar
real nice.. it looks great to me.. u have more pictures of it turned on and stuff like that :-)
Old Jan 13, 2009 | 09:24 PM
MikeButcher's Avatar
Originally Posted by acr
interesting, it looks like you have dual zone climate control but no premium package. did you replace the radio at some point, or solder in your own dual button?
The Canadian version of the car either came fully loaded or bare bones...the only other option was navigation...so I got fully loaded (sunroof, 19" rims, metal pedals etc) but no navigation...I think the cars that came out in '05 in the States had a lot more options...
Old Jan 13, 2009 | 11:47 PM
Here's another I took.
Happy to hear you like the way it turned out!
Old Jan 15, 2009 | 02:40 PM
Mr.PotatoHead's Avatar
very nice, im thinking about picking up the garmin nuvi 880 from
http://www.86photovideo.com/products...oduct_id=18634
does anyone else have pictures of the nuvi mounted in the cubby?
thanks
Old Mar 13, 2009 | 06:45 PM
ucf52's Avatar
Hate to bump and old-ish thread, but I'm just curious if anybody can comment on the reception of the their GPS in the cubby location. I have a Garmin Nuvi and this seems like a perfect location to mount it... I just want to be sure there is no issue with reception. Thanks for any replys.
Old Mar 13, 2009 | 06:57 PM
redlude97's Avatar
The reception on my NUVI 760 is pretty poor with the internal antenna. I actually installed an external one on the back of the rear view mirror and routed the cable back to the cubby. Signal is greatly improved
Old Mar 13, 2009 | 08:20 PM
ucf52's Avatar
Hmm, interesting. Thanks for the response... I guess I'll look into the external antenna addition.
Old Mar 16, 2009 | 01:22 PM
Oh Itz Joel's Avatar
did you use the regular car charger that connects to the piece that holds the garmin or did you just glue the bare garmin and using the usb charger?
Old Mar 21, 2009 | 10:08 AM
SoxUcf's Avatar
This is a great thread. It pushed me over the hump earlier this year when I was debating whether or not to hold off on buying my current G or to find the exact one with navi. I ended up getting a great deal and the only one with navi I found was $3500 more. I plan on going this route with the Garmin 885 (I hear the voice commands actually work).
Kind of weird that UCF posted his question (b/c I am in Otown too) but I never thought of there being a reception problem but I could definitely see that being an issue. Does anyone have any input for receipt quality in the cubby with the newest generation of Garmins? I believe the 760 was last years and I know my wife's 265 seems to have a leg up on her sisters 260 and that is with the 200 series not the higher end 700/800 series.
Redlude, so you installed an external antenna behind the rear view mirror? Can you explain more? I have never used an external piece for these portable GPS units and I am curious about the details. Did you run it with the wires with the homelink mirror similar to how people provide power to their wires for radar detectors? If so how connect the antenna piece to the garmin? Any pics or DIY? I am planning this install soon so I appreciate as much info as you have. The last thing I want to do is drop $400+ and a Saturday afternoon to find out reception is going to go in and out all the time.
Old Mar 21, 2009 | 03:19 PM
ucf52's Avatar
Hey Sox, I'm going to do a test run with my Garmin temp mounted in the cubby hole via velcro using the internal antenna. I have a nuvi 200w and their is no external antenna option for me
Anyways, I assume signal strength for the internal antenna will be roughly the same for the nuvi series. I'll report back my results.
Old Mar 22, 2009 | 09:09 PM
SoxUcf's Avatar
Ok sounds good. I am curious to hear how it goes, especially b/c we drive in the same area.
Old Mar 23, 2009 | 12:31 PM
ucf52's Avatar
I just got some heavy duty velcro... I'll post my findings later today.
EDIT: Well, I just got back from running some errands and the GPS worked just as it does when it's on the glass, so I'll be making a better mount for it and it's staying.
Old Mar 28, 2009 | 05:53 PM
SoxUcf's Avatar
Good it hear.... did you make the mount yet? What do you plan using?
Old Mar 29, 2009 | 01:51 AM
h0tsauce's Avatar
looks clean
could you listen to the navi through your speakers too?
Old Jul 4, 2009 | 06:29 AM
  #30
Keyser16Soze's Avatar
Is there any way to use the power from the mirror to power the unit. Rather than mounting into the cubby, keeping the unit high on the window, next to the mirror. Then use an adapter to link into mirror power?
