Stock navigation in non navi G35
Old Jun 14, 2004 | 09:56 PM
nismo4090's Avatar
I would like to put the stock navigation system into my car, I know that this would cost a lot but im just curious of exactly how much. If anyone else has any other ideas for a navigation system that would look clean please respond with suggestions. thanks
Back in Black
Old Jun 14, 2004 | 10:09 PM
mstil35's Avatar
Re: Stock navigation in non navi G35
$6000 to get a factory nav installed. WILL NOT be covered under Infiniti warranty. Also ECU would havew to be changed as well as a new main wiring harness. Go with an aftermarket unit. It can be mounted in the nav cubbyhole.
Old Jun 14, 2004 | 10:10 PM
mstil35's Avatar
With cubby cover closed
Old Jun 15, 2004 | 03:00 AM
JKDman's Avatar
mstil35 your setup looks very clean. How's the setup though?
Do you use both the stock HU and the aftermarket HU together?
Or just keep the Stock HU for show and use the aftermarket HU with NAVI for everything?
Was it hard to install in the cubby?
Lastly, how much did it cost?
Looks very sweet man.
Old Jun 15, 2004 | 09:13 PM
mstil35's Avatar
I have the Bose patched thru the Kenwood HU which is hooked to a JL500/5 amp. I listen to Sirius mostly (Thru the Kenwood Sirius Tuner) I have the Bose plugged into the Aux input of the Kenwood so I can utilize the stock steering wheel controls to control the Bose.
As far as the install, they had to modify the main heat/ac duct (cutting off the flow to the rear seat vents)
Install was $700, Kenwood 911dvd was $1600 ,and the Kenwood Nav unit was $1200
Old Jun 15, 2004 | 11:52 PM
JKDman's Avatar
whoa... everything sounded tight until the rear seat vents being cut off. I know i won't be having too much passengers (me = workaholic) but man, still seems kinda drastic.
More stuff to think about. Thanks bro. Any additional info would be sweet.
Old Jun 16, 2004 | 12:10 AM
jstwong's Avatar
An interesting install there. Where did you have it done?
Old Jun 16, 2004 | 01:59 AM
Cruz's Avatar
mstil35-
Very nice setup...a few questions:
-Is it toushscreen?
-Does the cubby hole lid close all the way?
-Do you need to hook it up thru an amp if you just wanted to use it as a DVD/Nav unit?
XMLM
Old Jun 16, 2004 | 05:20 PM
mstil35's Avatar
The work was done at Freeman's Car Stereo in Charlotte.
Yes, It is a touch screen.
The cubby door lacks about 1/8" from closing flush.
You do not nescessarily have to hook it up to an amp. The 911dvd unit puts out 22w per channel or you could use an FM modulator through the stock unit. The nav unit comes with a single powered speaker for the voice guidance.
Old Jun 16, 2004 | 07:41 PM
Cruz's Avatar
Nice...now I just have to find a reputable installer in the DC/VA area, or I might have to take a trip to NC.
XMLM
Old Jun 16, 2004 | 08:38 PM
jstwong's Avatar
Thanks for the info. It is always good to see what others have done.
Old Jun 18, 2004 | 03:27 AM
ASUG's Avatar
I am going to do that same install, is that something i can do on my own, i am going to use a Pioneer AVIC-N1 with a 6.5" LCD. is there ne way that the A/C will not get cut off in the back? I live in AZ, not too smart to be cutting off any A/C
Old Jun 18, 2004 | 08:57 PM
mstil35's Avatar
It depends on how far the head unit fits inside the cubby. If you want the cubby lid to close, you would have to slide it as far down as possible ( this is where the ac duct mod comes in) If you want to have the head unit protruding out of the top of the cubby, you would not have to cut the a/c duct, but then the cubby door would not close. You could probably install it yourself, just take your time. After having mine in and out so many times, I could probably do it in my sleep now!!
Old Jun 18, 2004 | 10:31 PM
Cruz's Avatar
So does your A/C work properly the way you have it installed?
XMLM
Old Jun 19, 2004 | 09:34 AM
mstil35's Avatar
Yes, the A/C works but not the rear seat vents (the ones mounted in the rear of the console)
