4-chanels AMP, Front comonent and rear upgrade
Old Jun 15, 2004 | 11:32 PM
Ratman's Avatar
Hi guys,
I have the couple 5AT with Premium BOSE. I want to upgrade the front component and the rear 6X9. I have:
Rear 6x9 Infinity INI 9603I
Front 6.5 Infinity INI 6000CS
4 Channel AMP: Infinity INI 7540A.
I see your intruction on how to rip out the panels... Are there any way that I can just use the connection from the existing BOSE AMP.
I figure, the Power, Remote, and Input should all be there already right?
Do I need to open the HU to get the output from the the HU to the AMP?
Please give me some advice on how to install it.
Thank you very much
Old Jun 16, 2004 | 03:05 AM
trovan's Avatar
Re: 4-chanels AMP, Front comonent and rear upgrade
everything you need is in the trunk. there is a DIY. i followed it and was great.
2004 Blk/Graphite/6MT/Premium/Nav/Spoiler/XM/Splash/Formula1tint
Old Jun 16, 2004 | 09:12 AM
g35john's Avatar
Do not use the power from the trunk.. Run a new power wire with fuse to your bettery. The power for the bose amp is Way too small. Use at least an 8 guage power wire if you just running that one amp.
"Dont start none, Wont be none"
Old Jun 16, 2004 | 09:38 AM
Ratman's Avatar
Thanks for the tip. I plan to run another AMP about 600W for 2 10" Polk Momo too. What wire size I need for that distribute power block?
One thing bother me is that, what da hell should I do with the Stock Sub in the rear panel? Doesnt make sense to add a new Sub, and keep the stock sub huh?
Ratman
Old Jun 17, 2004 | 12:51 AM
bamadog's Avatar
Black 2004 G35 6MT, chrome wheels, black, still pristine
I don't have one of those since I don't have the premium system, but you can remove the sub itself to allow an air pass-through from the trunk to the inside of the cabin. If you can't remove it, or don't want to, with that kind of power/sub, it shouldn't make much difference.
The Bamadog
BAMADOG.COM
2004 G35 Coupe - Black/Black 6MT - Chrome 7-Spoke Wheels - Aero Kit & Package w/spoiler - Tint - Alpine System - Body Side Molding
Old Jun 17, 2004 | 01:49 AM
trovan's Avatar
you should use a 4 gauge wire and distribute the power via a distribution block to the two amps. i left my subs there.....
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
