Which double din kit should I get?
There's 3 different versions of the JDM Double Din Kit.. Wondering which one I should get?
I have a 07 G35 Coupe, non-premium, non-bose
- Regular conversion kit
- Dual AC Control
- Radio Control and AC Control Kit
Can you tell me the difference between the 3 kits? Like can I use the Dual AC Control in my car?
Thanks in advance!
- Dual AC Control
Thanks in advance!
The 1st and 3rd are the same thing, which in that case you CAN'T use the Dual AC, unless you take the Dual AC button from your stock dash and put it on the JDM kit.
The 2nd, you can use the Dual AC, which saves you the trouble of swapping everything.
I just picked up a Dual AC from Riverside today, and it was already shipped!
don't think you can do it easily. think you'd need to replace many parts.
the clock information area, (likely the wiring harness going to that) the controller unit, and likely have to add an independent blower motor for the passenger side. - I'm just guessing on the last one. but those other 3 things for sure
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
