Newbie Install Question
Old Feb 2, 2009 | 09:48 PM
menace321's Avatar
I have and 04 G35x Coupe with Factory Nav, Bose and amp. I have ordered the Nav2go Kit, a rear headrest flip down LCD, Parrot 3000 with factory molex, and a modded xbox media center to throw in. My only concern is if i disconnect the radio and/or nav, will it still work when i reconnect it or does it require a security code?? What if i also disconnect the Battery for and Amp & Sub install? I have spend 5-6 hours on these forums and learned tons and found tons of hot mods, but i dont want to screw anything up in the upgrade process. Any help would be appreciated.
Old Feb 2, 2009 | 11:55 PM
Deluxe121's Avatar
it should work, i just did mine and theres no security code i had to put in
Old Feb 3, 2009 | 01:15 AM
menace321's Avatar
So if i disconnect every wire on the radio, when i plug it all back everything [nav, radio, a/c] will work?? I want to make sure. I want to make my car and ongoing project and will make a thread for other newbs to follow. But i want to make sure i get my info right.
Old Feb 3, 2009 | 12:09 PM
TroysG's Avatar
as long as you plug everything back in to the right spot you'll be fine
Old Feb 3, 2009 | 05:56 PM
menace321's Avatar
Thanks for the info guys. Ill let u all know how it goes.
M3nace
jsimonk
Dec 22, 2023 03:49 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
