Signal Prossesing ,YES or NO ??( Original HU)
Old Feb 14, 2009 | 06:08 PM
randyc's Avatar
With the premium Bose System, if i only keep HU and change everything else , is prossesing the outcoming signal nessesary or not ??????????????
Old Feb 14, 2009 | 07:28 PM
pattyskin's Avatar
If you buy an amplifier which can accept balanced inputs then you should be fine.
Old Feb 14, 2009 | 09:31 PM
TroysG's Avatar
I disagree with Pattyskin.
if you want decent sound get a sound processor (JL cleansweep, Rockford 360.2) something along those lines. you will be set for better sound
Old Feb 15, 2009 | 04:51 PM
releasedtruth's Avatar
How about this, Randy, get your business all set up, see how it sounds. If not adequate, Cleansweep or 3sixty it. that way you aren't out the money if you don't need it.
Old Feb 16, 2009 | 01:30 AM
The Stimulation's Avatar
3sixty = fail. Bluetooth module will eventually crap out. Happened to a friend of mine and a couple other people I know. Will cost over $100 to fix as well. I'd go with the Audiocontrol LC8 if using factory radio. There is always the Alpine H650.
Old Feb 16, 2009 | 09:32 AM
TroysG's Avatar
my old boss has had the 360.2 for 3 years now and hasn't had any problems♠
jeffbdye
Jun 1, 2018 03:51 PM
Learned Hand
Oct 1, 2015 09:02 AM
