PAC SWI-X Memory?
Old Jun 20, 2004 | 03:21 AM
afr0puff's Avatar
Supa Dupa Moderator
PAC SWI-X Memory?
Do you have to reprogram it every time the batter gets disconnected?
http://www.anythingbox.net
Old Jun 20, 2004 | 12:38 PM
JohnBoy's Avatar
Re: PAC SWI-X Memory?
I don't think so. There's no constant power wire (only a switched wire) so you're disconnecting power to it each time you take the key out.
Old Jun 20, 2004 | 11:24 PM
GRider35c's Avatar
no...
"Once connected, the SWI-X's failsafe memory will learn up to 12 functions from your receiver's wireless remote, retaining them even if battery power is interrupted." Crutchfield.com
04/BO/G/aero/splash/prem/perf/cc/22%tint
Old Jun 21, 2004 | 12:42 AM
afr0puff's Avatar
Supa Dupa Moderator
Thats odd... i disconnected my battery and it lost everything.
Old Jun 21, 2004 | 12:44 AM
GRider35c's Avatar
that sucks!
my installer had a hard time programming the thing over the weekend...
you got any tips... can you teach me how to do it?? he sure as he!! cant figure it out!!
Old Jun 21, 2004 | 08:48 AM
afr0puff's Avatar
Supa Dupa Moderator
That thing was a bitch and a half to install properly. But once I got it, programming was pretty easy. Does your HU have a IR remote? Is it compatible with the swi-x? If you still can't program it, then it wasn't installed properly. If you need help, I can walk you through it.
Old Jun 21, 2004 | 09:53 AM
JohnBoy's Avatar
A little off topic but, where do you guys have your led mounted? I'm still looking for a good place for mine. Leaning towards the map light area but also considering near the steering column or gear shift.
Old Jun 21, 2004 | 10:21 AM
afr0puff's Avatar
Supa Dupa Moderator
I haven't completed my install yet, but I noticed what a crappy angle range that thing has. I wanted it off to the side but no luck. I have a 6MT, so I think I am gonna have it in between the heated seat switches facing up.
Old Jun 21, 2004 | 11:39 AM
RamboRami's Avatar
G35driver.com Moderator
but what if your arm is there resting or shifting....it'll be blocked
wouldnt the best place be in the map light but angeled forward somehow?
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake/AVIC-N1-double-din
Old Jun 21, 2004 | 02:20 PM
afr0puff's Avatar
Supa Dupa Moderator
I didn't have a problem when I shoved it in the sliding cup holder area. It depends on what center console you have. If its the 2003.5 and above 6MT, then the heated seat swithces are off to the side and will clear the shifter. If I put it in the map light area, I wouldn't have any place for the "black box" it comes with. I use my sunglass holder all the time. I should be done by this weekend, so I'll post pics when I get the chance of where mine is located and how well/poor it operates.
Old Jun 21, 2004 | 05:27 PM
GRider35c's Avatar
mine is located above the passenger side window... at least thats where my installer put it! we'll see if it works...
Old Jun 21, 2004 | 08:42 PM
RamboRami's Avatar
afr0puff,
yeah i see how it will clear the shifter.. might be close when in 6th gear but you should be okay. good luck man
Old Jun 26, 2004 | 01:57 AM
afr0puff's Avatar
Supa Dupa Moderator
Grrrr... the range/angle on this thing blows. I now have a useless hole between my heated seat switches. It was way too inconsistent from there. Might work better in that location with a different HU. Plus the upward sloping console doesn't help matters. I really don't want to lose my sunglass holder, but I see no other choice.
Old Jun 26, 2004 | 01:29 PM
GRider35c's Avatar
put it here, it works great!
Old Jun 26, 2004 | 01:30 PM
GRider35c's Avatar
zooooom...
