infinity basslink
Old Feb 16, 2009 | 03:06 PM
suby01's Avatar
infinity basslink
im looking at getting a powered subwoofer and what i found was the infinity basslink.
im interested in the basslink 2.
i have a couple questions...
whats the difference between the two products. is it only the obvious part of the 200 to 250 watts?
what would be the best place and way to mount this standing up or laying down. and in the back corner of the trunk or up in front by the rear seat?
my guess i wouldnt need anything bigger than a 8g wire kit and a 60amp fuse should be enough for the setups.
http://www.infinitysystems.com...d=BSL
thanks
Old Feb 16, 2009 | 05:00 PM
blazeplacid's Avatar
I belive the basslink II has a passive radiatior and the ability to add a 4 chan amp to the unit it self
Old Feb 16, 2009 | 06:24 PM
TroysG's Avatar
8 gauge will work fine
Old Feb 17, 2009 | 10:34 PM
releasedtruth's Avatar
I've seen them often in the corners behind wheel wells standing up. Never heard the v2, but the first version was a decent, cheap solution.
Old Feb 18, 2009 | 04:00 PM
suby01's Avatar
^^ so do you think it would be a noticible upgrade?? the only reason im going with the basslink is of the lightweight and small space and just want something to give off a define bass feel.
i know i can get something way better. i have a $1000 audiobahn amp in the basement that weighs about 50-60lbs and just adding some 12s would be the easiest way...but this is not the route i want to go with my G. thanks.
Old Feb 18, 2009 | 05:47 PM
TroysG's Avatar
if you're just looking for a little lower end fill it will work. don't expect "mind blasting" bass.
g35coupe2
Sep 17, 2015 04:00 AM
DRG35R
Sep 16, 2015 05:33 AM
twentyeggs
Sep 11, 2015 03:58 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
