Why LOC?
Just get a pair of twisted-pair RCA's that are easy to splice and splice into the harness BEFORE the amp so you get the full bandwidth signal to start with
oops i forgot the "if he has the bose system" part and just assumed he did
Here is the answer I think you are looking for. On the Bose system, the head unit outputs ARE low level signals (pre-amp level, not speaker level, whatever you want to call it). The issue that some amps have with connecting the low level signals directly is that the outputs from the Bose HU are DIFFERENTIAL/BALANCED. Not all amps know what to do with this type of signal. Most RCA's that come with aftermarket radios are single ended, not differential.
A lot of times people can use a LOC to convert the differential signal from the Bose HU to single ended to use with amps that cannot handle differential signals. I know the JL amps can handle differential inputs, so you can splice them directly.
Hope that helps
Hope that helps
I should have mentioned I do not have bose system, just regular stock hu w/ out the stock amp in the trunk. So still high level inputs or should I LOC to RCA's??
Hope that helps
Hope that helps
I am so not looking forward to bearing four more wires and splicing and what not.
Or do I just need to use the LOC on the low-level outputs I've already tapped to get rid of this differential or balanced business. (They are the same thing, right?)
if you have an amp that takes speaker level inputs, like the alpine ones,
can you just connect to these speaker level inputs by tapping into the speaker wires going into the BOSE amp?
speaker level inputs would eliminate the need to use RCAs right?
No. The Bose HU does not have speaker level outputs. That is why the Bose amp is there.
I would assume LOC. If the non-bose HU outputs speaker level, you could need a LOC unless your amp accepts speaker level inputs. I don't have a non-bose, so I can't be 100% on that.
Tapping into the post bose outputs almost defeats the entire purpose because you are still going to have all the bose processing done. If you splice in RCA's into the post-bose outputs and hook it up to your line-level inputs on your 500X, you are going to be overdriving it horribly. You will be hooking up speaker level wires into your line level amp inputs. It does look like the 500X has speaker level inputs, so it is one way to do it. Again, you will still have all the bose processing though.
You should be able to use a LOC to convert the differential to single ended before the bose amp.
Well this must be why my system doesn't sound nearly as good as it did in my other car with my pioneer HU. I think I'm gonna just tap into the post-Bose outputs too. I guess I shouldn't need an LOC since I have line-level inputs on my rockford fosgate 500X. Anyone know if that one is one that can accept the balanced inputs from the Bose HU? How does it sound when it can't accept balanced inputs?
Thanks Midnight. I think I'm going to be trying one of the AudioControl signal processor things from Crutchfield. They've got a whole list of units. I had not expected to be out of a hundred or hundred and fifty smackers, but I guess this might be what it takes. The Crutchfield guy I talked to recommended that MTX re-Q thing. It doesn't say specifically that it accepts balanced differential input like the LC7 or that 600 dollar DQL-8 say explicity, but one of its features listed in the hands-on research tab is "balanced bass." Not exactly sure if it's doing the same kind of processing that the LC7 and DQL-8 are probably doing, but I guess there's only one way to know for sure: ordering it and hooking it up. I may just go ahead and order an re-Q and and LC7 and see which is best and return the other, which Crutchfield allows. Only thing is the LC7 is currently out of stock. I'll bet people on this site bought them all.
I would email Scosche about the SLC-4 on crutchfield. http://www.crutchfield.com/p_142SLC4...4.html?tp=2001
Just ask them if you can hook up a differential input to it. The SLC-4 has a gain setting, so you should be able to boost up the signal or not. I don't think you need to spend $100+ just to get a signal to your amp that will work.
