RF 3sixty
RF 3sixty
Has anyone had a successful setup of the RF 3sixty with an aftermarket amp setup?
Mine has some alternator whine and static.
I am going to change the ground and power to connect to my amps ground and power,it was suggested by the Rockford techs.
rcas are down opposite sides?
rockford isn't screwed down to chassis?
Factory deck aftermarket?
1. If you mean opposite sides from power then yes.
I use the stock rca from the deck.
2. I don't need the 3sixty screwed down to chassis it grounds from cable not the body.
3.The deck it factory.
On the DIYMoblie forum many people are setup correctly but still have alternator whine and hissing at low volume on there 3sixty's.
Do you have a working 3sixty?
Thanks for the reply
