ZEnclosures G35 2-10" Subwoofer Enclosure - how much actual air space in one?
Old Mar 30, 2009 | 06:45 PM
kingrukus's Avatar
I am looking at purchasing the ZEnclosures G35 2-10" Subwoofer Enclosure for my coupe. The ad on ebay lists them as having 0.80 cubic foot, but then it says that there is only 1 chamber and that the 0.80 cubic foot is the total space within it....I find it hard to believe that they would only allow 0.40 per subwoofer.
Can someone please tell me the actual airspace within one? Further, did you guys find them to "choke" your subwoofers from air and cause them to only hit high notes?
Thanks
Old Mar 30, 2009 | 06:56 PM
redlude97's Avatar
it is actually that tiny. Very poorly designed for the coupe and certainly not optimal for any 2 subs. Go with dual 4080 boxes if you want 2 10's
Old Mar 30, 2009 | 07:05 PM
kingrukus's Avatar
Wow if thats the case then I won't even bother at all. This really sucks...
Old Mar 30, 2009 | 09:51 PM
releasedtruth's Avatar
I read the same thing which sounds really odd to me. You'd think it would have to be 1.4cf or so to be reasonable
Old Mar 30, 2009 | 09:58 PM
kingrukus's Avatar
okay I contacted zenclosures and even they do not reccomend the box, look what they wrote me:
Hi
The box is .80 total...0.40 per sub. We recommend this box for 1-10" or subs that work in a small box when going with two.
Old Mar 30, 2009 | 10:15 PM
http://cgi.ebay.com/Infiniti-G35-Coupe-Custom-Sub-Subwoofer-Box-Enclosure_W0QQitemZ300259193812QQihZ020QQcategoryZ50565QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Sweet paint, 1.7cf airspace and a lot less than 2 4080s...
Old Mar 31, 2009 | 02:54 PM
blazeplacid's Avatar
shallow mount subs work with about .4-.7 cubes of air
just a matter of getting the right sub for the box
look at Rockfords slim line
or maybe even tang band?
Old Mar 31, 2009 | 03:14 PM
stealthlude00's Avatar
agreed, i got one with 2 JL w3, they really don't hit as hard as they did with my big box that barely fit in the G's trunk. Don't get me wrong, it still hits hard, you just have to get the right sub as someone above just said! JL W3....not the best one cuz if i push one sub lightly, i see the other sub move in the opposite direction, as if there's not enough air space inside...come to think of it, is it possible to modify this sub box? Can i take off the back, add about 2 inches of MDF all around, make sure its sealed, then put the backing back on???
Old Apr 2, 2009 | 08:11 PM
NaiveRapture's Avatar
You could do that, or even take off the sides and make it wider.... I think there's plenty of space on the sides as well! Hell, take the whole back off and re make it haha.
I have this box with one 10" JL W6 and it works pretty well!
The OP, you could also reverse mount the subs.... that way you've got the basket sticking out into the trunk space, this would give you a lot more internal volume.
Old Apr 2, 2009 | 09:58 PM
kingrukus's Avatar
invert mounting would only give you about an extra 0.05 to 0.1 cubic foot per driver (depending on the driver) which in my opinion isn't much at all...but I suppose if you are dealing with a 0.8cubic foot box in total, then it makes a difference. overall this box is WAY too small for 2 10's....its ideal for 1 10", and that is the model I would buy if I were going to.
there was someone local to me selling the zenclosures dual 10" enclosure, that was the only reason why i was interested in this enclosure to start. however if I have to modify it, I will build my own enclosure from scratch.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
ZacDesu
Jul 14, 2015 11:13 PM
