Serious issue in my car electronix
Old Apr 7, 2009 | 10:29 AM
fouad1111's Avatar
NEED HELP! Serious issue in my car electronix!
Hello,
This is the first time i post and i hope someone out there can help me.
well the below is my problem:
I got a g35 coupe 2003, my problem is that the dash console where I should see the tach, and fuel economy etc is not working.. it is not lit..everything else is lit (radio and ac buttons...)
in addition to that, when i put reverse, i get no white reverse light in my tail lights in the back..they are not working..
first thing on my mind is to check the 3 box of fuses and found that the "Elec Parts" fuse is blown.. so i replaced it and as soon as i set the key to ON when i am about to turn on the car, the fuse blew back..
again i repeated what i have done and replaced the fuse and tried again to turn on the car.. and as soon as i do that i blew it again..
well my car was in an accident lately but the accident was to the rear.. not to the front..
so i appreciate any help from anyone .. if there are any diagram..
i think there is a short circuit happening somewhere.. is there any diagram that i can follow or any hint that might help?
Old Apr 7, 2009 | 12:20 PM
DiGil's Avatar
the fuse is blowing, you have a short somewhere. You know the reverse lights aren't working and you recently got hit in the rear, I'd say check for damage and a short there. Just a guess though.
Old Apr 8, 2009 | 03:05 AM
fouad1111's Avatar
I checked the tail lights and everything seems in good shape. they are new tail lights. i even disconnected them and still the fuse is blowing..
i agree that there is a short somewhere but i disconnected everything (even the car seats, the console, the transmission solenoid, everything..) and still.. i can't get a hold of this short!
i took it yesterday to the electronics shop and the guys are checking it wire by wire..
until today they couldnt know what is the problem..
i will let you know what happens.. thank you though for your help..
Old Apr 8, 2009 | 03:06 AM
fouad1111's Avatar
just one question, do you know what is the fuses "elec parts" responsible for?? what does it control??
thanks
Old Apr 8, 2009 | 08:15 AM
fouad1111's Avatar
ok finally got a solution!
two wires due to heat melted on each other and created a short circuit!
now everything is back to normal ..
Old Apr 8, 2009 | 10:29 AM
PeterUbers's Avatar
wow! that's a scary thought ... why did they melt together???
Old Apr 8, 2009 | 03:44 PM
fouad1111's Avatar
i guess because of the rear hit in addition to heat..
it took around 12 hours of work to discover that!
chinee
Jun 10, 2024 07:48 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
tiguy99
Jul 26, 2015 01:39 PM
itschuckster
Jul 25, 2015 08:07 AM
