how do i hook my iphone into my factory bose system
So the search fuction sucks..sorry i tried but i need help.
I have a 2006 G35 coupe with 6mt and factory bose system. what do i need to purchase to connect my iphone into my car and where do i get it from. thanks
Shaun.
Shaun.
You can use the scoshe passport to enable charging...
http://store.apple.com/us/product/TS...mco=MjIwMTg2NQ
Apparently, Apple had the info regarding the powering issue with the new iPods for a long time on bullitins, etc, but the manufacturers never bothered with it, presumably to make you buy more crap.
" Radio must have a "SAT" button or have "CH", "CHANNEL", "CAT", or "CATEGORY" printed somewhere on the face of the radio. This is usually located near the Tune or Seek buttons
o In 2004-2006 Infiniti vehicles equipped with factory satellite, the satellite receiver will have to be disconnected at the satellite tuner location in order for the PXAMG to work correctly"
I'm not too sure how the search function sucks so much since that was how I found out all the info I needed when I was looking for mine. Im thinking somebody is just impatient and lazy. https://g35driver.com/forums/search....archid=7330773, http://www.myg35mods.com/.
There is a ton of information on these forums if you actually try looking around and reading through threads. I am pretty sure the peripheral electronics one will charge and iphone, but I think you need to buy a different adapter for it from them.
Wingnut - what buttons do you have by your Radio button? Im pretty sure as long as you have a post 9/03 with premium bose audio, you should be able to use most of these.
Next weekend I plan to install the factory XM unit. I plan to do some research to see if I can use the XM unit and the Ipod unit together. If so, I'll just install them both at the same time.
Freeman186
Sep 6, 2023 10:07 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
