Labor costs for applying Dynamat?
Old Jul 8, 2004 | 03:12 AM
ryanwiggum's Avatar
For those with sound deadening materials, how much did labor cost you? Just the labor (applying the mat to the most common trouble spots in the g35 coupe), I'm going to buy the product myself.
Old Jul 8, 2004 | 10:10 AM
afr0puff's Avatar
Supa Dupa Moderator
Re: Labor costs for applying Dynamat?
I'm assuming it would cost a lot, considering it's such a pain in the a$$!!! If you estimate 4 hours, it will take 8!
http://www.anythingbox.net
Old Jul 8, 2004 | 11:47 AM
al503's Avatar
Most places where I live charge their hourly rate which is around ~$60. I would consider diy if you have the time and save a lot of $.
Old Jul 8, 2004 | 07:19 PM
limeg35's Avatar
i dont know the cost of the labor would be[img]/w3timages/icons/frown.gif[/img]...but you should've negotiated that along with the system you've just installed, most of the shop are willing give you a lot of discount on sound deading when they are try to sell you on the systems, besides they have to tear it apart anyway to run the cables and wires.....by the way i like your HU, i had same one, before i switch it out for AVIC N1.
03 coupe 5AT DG/G premium,performance,
AVIC N1, Volk GT-7
Old Jul 9, 2004 | 03:33 AM
g35mt's Avatar
the problem with the audio shop, sometime they take shortcut. It happen to me before and that is why i chose to do it myself. When i do it, i know every inch of the door will be dynamat. i think you should do it urself, at least you know it will be done properly.
Old Jul 11, 2004 | 12:19 AM
MikeyMike's Avatar
Rollin On Dubz
But where are the trouble spots to dynamat? I have the sedan. I know the trunk would need to be dynamatted, but where else? Anyone got any experience?
Old Jul 11, 2004 | 01:09 AM
limeg35's Avatar
one of the place that most ppl over lQQk at, is on the outside of the car, around the license plate bracket, it give out more noise than anywhere else!
AVIC N1, Volk GT-7
Old Jul 11, 2004 | 05:32 AM
g35mt's Avatar
yup..i did that outside near the license plate. It helps reduce alot of vibration.
Here is what i have done for far. As mentioned above, the outside of the car near the rear license plate. I also did the trunk, the rear seat, the rear panel (both against the outer wall and inner wall, the rear wheel well. Off course the most important is the front door. The front door both layer. The door consist of a metal plate that reside between the outer most portion of the door and plastic piece.
I have only three thing left...the bottom floor, all the tops and lastly the engine bay area. It probably a 2 years on going project as i am lazy **** ****..hehhee [img]/w3timages/icons/smile.gif[/img].
g35mt
Old Jul 22, 2004 | 03:23 AM
ryanwiggum's Avatar
i guess i'll try doing it myself
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
wow600rr
Sep 28, 2015 11:50 AM
Detailed Image
Sep 28, 2015 07:04 AM
