Help! problem with amp
Old Apr 28, 2009 | 11:54 PM
Blitz1350's Avatar
So recently i wired up a sub and amp to my g35. For my rem wire i sliced into the factory amp rem wire. Everything worked for a while and then all of a sudden my amp wont turn on. so i took a wire and connected it to the positive terminal of the amp and where the rem wire would go and all it does is power up and then no speakers will work. Thats where i am confused. Any help would be appreciated! Thanks
Old Apr 29, 2009 | 08:02 AM
TroysG's Avatar
where did you get the signal for the amp? if you got it after the bose amp and it's not turning on you'll get no signal.
If you replace the fuse to the bose amp that should turn the bose amp back on and you'll have signal again.
Old Apr 29, 2009 | 11:11 AM
g35rcr's Avatar
tap the signal off your deck subs...your remote line id tap into the ignition wire
Old Apr 29, 2009 | 02:57 PM
Blitz1350's Avatar
I have a Line out converter to get the signal for the amp.
i will replace the fuse on the bose amp and see if that will help.
Thanks.
Old May 5, 2009 | 05:41 PM
Darkchyle20's Avatar
Not to sound ignorant but where is the fuse for the Bose amp located? I am having an issue where I am getting no sound from my speakers. This just happened overnight. Before I conclude that the Bose amp is dead, I want to check the fuse to verify that it doesn't need to be replaced.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Ohsixgee35
Sep 16, 2015 04:33 AM
mattdg35
Sep 14, 2015 11:28 AM
Mhacker
Sep 12, 2015 07:35 PM
Jnm07
Sep 5, 2015 01:16 AM
