easiest way to get to the passenger door speaker?
Old May 8, 2009 | 09:30 PM
Rob21r's Avatar
Ok,
Since I got my windows tinted my passenger side door speaker keeps cutting in and out. It is being run off a seperate 4 channel amp and I checked all speaker connections there and everywhere else in the car besides at the speaker itself. How hard is it to get to that door speaker to check the connection there? I am thinking that some of the soapy water from getting the window tinted got on the connection and is causeing it to cut in and out. I'm almost posative its a short just by the way it cuts in and out. any help will be appreciated
Old May 8, 2009 | 10:04 PM
Vrod-Mike's Avatar
I doubt that is your problem and even if it was as soon as it dried out the problem would go away. It's possible the connection on the speaker is loose, but it's just a coincidence that it happened the same time you tinted the car.
Old May 8, 2009 | 10:32 PM
Matthaios's Avatar
Getting to the speaker is really easy, you just gotta take off the door panel. It only takes about 2 minutes to do. Just search the forum on how to remove it, there were a couple guides on how to do it.
Old May 8, 2009 | 10:46 PM
Rob21r's Avatar
was thinking that the soap used could have made the contact not conduct right. I have a RC race tommorrow so I will have to mess with it on sunday after going to the French Quarter with my mom. Thanks for the information.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35-R
Nov 7, 2015 01:21 PM
itgogitrev
Sep 23, 2015 07:08 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Mikesta
Audio/Video/Electronics
Sep 10, 2015 05:14 PM
