Need help adding sub to 07 G35S w/ prem/tech/nav package
Old May 18, 2009 | 02:03 PM
seeker92677's Avatar
Let me start by saying, I do know where the search feature is and have used it.
I want to add a sub to my G sedan. As the title says, I have the prem/tech/nav packages and for the most part, have been very satisfied with the system, but I miss the thump of a sub from my old car.
I want to find out what my options are to add a sub (and IPOD jack for that matter, but very secondary). I know there are kits on E-bay to add an IPOD to the Bose system, but they all say not with the nav package. I want to know if there are any available pre-outs, or if my only option would be to hack into the high-level outputs.
thanks for the help.
Old May 18, 2009 | 02:19 PM
B L U E S L A T E's Avatar
Honda Accord
I don't have time to look for it now, but if you search, you'll find a thread about this from back in 2007 in Tech section. Quite a few members have added subs to their cars and so did I. Also, it'd be helpful if you had a copy of service manual as you'll have to tap in a PAC Audio SNI-35 SNI35 Adjustable Line Output Converter from your factory "Amp to Sub" wires. It was also helpful to look at some of the DIYs from the older G coupes as the wire connections were quite similar.
As for iPod, why can't you use the RCA output in the middle?
Old May 18, 2009 | 03:00 PM
Thanks for the heads up, I have tried to search there before, but I will take a look again.
As far as the IPOD goes, it would be nice to be able to charge and use built-in controls.
BTW, I noticed you are in the OC, where abouts? I'm in San Juan Capo.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
nissandrifter32
Dec 22, 2015 04:28 PM
MrIP35
Oct 25, 2015 11:13 PM
SuperSaiyan
Sep 23, 2015 06:13 PM
bigmike
Sep 17, 2015 01:58 PM
