New and I have some questions
Old Jun 11, 2009 | 12:25 AM
infiniti g's Avatar
Hi,
My name is colin, im 17 and i recently purchased an 03 g35 sedan. I did a DD conversion yesterday and it took a long time. After I finished that i made an attempt at installing my 2 12" Rockford Fosgate subs and my amp, The only problem is that after wiring everything im not gettinganything from the amp. I was wondering if anyone had any suggestions on troubleshooting to find the problem.
Thanks
Old Jun 11, 2009 | 02:58 AM
PeterUbers's Avatar
Hi Colin, welcome to the forum
Unfortunately, with what little information you've provided, I can only point you in some basic directions:
1) i presume the rest of the audio system is working the right way, correct? You hear the rest of the car's speakers working in all modes (CD, Radio, Ipod, etc)?
2) How did you wire up your amp? Gee, what kind of DD did you install? That'd be good info to help us help you
3) Where are you getting power from for your amplifier? have you tested this with a voltmeter to see if you're getting 12 volts to the amplifier? Do you have the amplifier well grounded?
4) How did you wire up the subs? Is your amplifier only powering the subs, or is it also powering the midrange and tweeters too?
5) Does the amplifier light come on? Did you tie in the amplifier turn-on wire correctly?
My questions and my advice is going to be vague, because your question was vague-- have to help, though.
Best of luck.
Old Jun 11, 2009 | 09:20 AM
infiniti g's Avatar
Best of luck.
1 I did not replace the speakers and yes they work in all modes
2 I put in the metra kit which wasnt to bad with a single din pioneer Deh P6000 UB and i just wired my amp normally i guess
3 I am getting the power from the car battery and it is grounded to the chassis
4 The subs were prewired and the amp is only going to be powering the subs
5 No i think this might be my problem is there any way to test the turn on lead
Sorry for the lack of info but thanks for the help
Old Jun 12, 2009 | 12:47 AM
Bigrose's Avatar
I would recheck all the connections from your headunit to your amp (Remote, RCA) and your power and ground connections as well. After that, check the inline fuse and the fuses on your amp. If all that is correctly connected and the fuses are good, you might have a problem with your amp. Actually, at that point, it could be anything.
Either way, good luck and welcome to the forum! Enjoy your G, bro!
Old Jun 12, 2009 | 09:44 AM
infiniti g's Avatar
thanks
I actually dicovered my problem it was the turn on lead, it got wired incorrectly which also led to the signal booster not working but its all fixed now and the subs are really loud my only problem now is to find a way to stop everything from vibrating so much
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
