my ac wont turn off!!
Old Jun 15, 2009 | 07:29 PM
916_G35's Avatar
Exclamation my ac wont turn off!!
i have this problem for about 3 months now!! my ac turns on by its self and and my center consol( all ac buttons... sterio buttons dont work) but i can contron my sterio from my steering wheel.. i heard this has happend to alot of G35 out there. but i have not seen an answer.
i have disconected the battery check my plugs in the a/c motor but no luck..
Old Jun 15, 2009 | 08:33 PM
04G35NYC's Avatar
^ do you have 03/04 Coupe or sedan? if so the the problem is with the Circuit board it's a known problem, good thing i got rid of it and replaced it with JDM kit with a new head Unit.
Old Jun 15, 2009 | 09:52 PM
916_G35's Avatar
i have an 03 coupe.... how much did you pay for the jdm unit?
Old Jun 19, 2009 | 06:45 AM
ferris196802's Avatar
it is definately the stereo, you need to replace the stereo that controls everything, i changed my stereo with another v35 i have and it works.
Old Jun 19, 2009 | 11:26 AM
04G35NYC's Avatar
$300 shipped from Riverside Infinti.
Old Apr 25, 2012 | 04:32 PM
epontess's Avatar
I have this same problem! It drives me crazy!!! It's so expensive to repltace that thing.
Old Apr 25, 2012 | 04:55 PM
william747400's Avatar
yea JDM Double Din kit is the way to go.
You get rid of the problem and get yourself a nice touchscreen with a lot more functions than the stock headunit.
Old Apr 25, 2012 | 05:24 PM
epontess's Avatar
I was reading about the jdm kit on there site and it says I would loose dual climate control? I got a 03 coupe. Is this true?
Old Apr 25, 2012 | 06:08 PM
GR6RR's Avatar
^ de-solder the old one and re-solder onto the new one.
Old Apr 26, 2012 | 09:56 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Check the FAQ section of the sticky:
https://g35driver.com/forums/audio-v...urce-list.html
Old Apr 28, 2012 | 01:29 AM
Top Teke's Avatar
Welcome to the exciting world of aftermarket HU.
Old Apr 30, 2012 | 04:34 AM
Hybird's Avatar
I found if you give the center controls a really hard open palm slap it some times makes everything come back to life. I had this same issue, its very common for these earlier year models. I did like most other and went to a double din center console. You need to by the jdm plastic center piece, the single a/c board, and a new stereo, then pull out that bose pos that will likely break on you anyways and beat the hell out of it with a bat.
Old Apr 30, 2012 | 09:25 AM
epontess's Avatar
Looks like I will be doing lots of slapping while I save up around 800 for a new set up.
Old Apr 30, 2012 | 10:03 AM
Top Teke's Avatar
Haha. 800 bucks will get you a pretty sweet HU/DD setup. But make sure you do the right thing and get JDM
Old Apr 30, 2012 | 12:16 PM
epontess's Avatar
Everyone keeps telling me to get the jdm kit but its like 300 bucks for a peace of plastic!!! But it will look cool once installed.
