Bose Amp with aftermarket HU
Old Jul 20, 2009 | 01:10 PM
obsidianvq35's Avatar
Arrow Bose Amp with aftermarket HU
When installing an aftermarket Double-din, does this have an affect on the bose amp with the speakers?
Old Jul 21, 2009 | 07:54 AM
Gilley's Avatar
Yes. You have to connect the aftermarket HU to the Bose amp to get any sound, unless you're installing an aftermarket amp.
Old Jul 21, 2009 | 08:03 AM
I understand that. As far as sound quality of the speakers and amp, will the bose amp and speakers work to the same extent as with the factory HU or will it be altered in some way? Thanks
Old Jul 22, 2009 | 05:19 PM
TroysG's Avatar
you will get much better sound.
Old Jul 22, 2009 | 05:33 PM
If my new Double-Din HU has a built in amp do I use the stock bose amp or use the double-din amp for the speakers?
Old Jul 22, 2009 | 08:08 PM
Gilley's Avatar
you're better off to replace the Bose amp than the HU for an improvement in sound, but replacing the HU will still give you more flexibility to make the sound better.
You still need to use the Bose amp with your HU unless you want to run speaker level wire from the HU to the Bose amp output to send the signal to your speakers. You could also run speaker wires from the back of the HU to each individual speaker.
Most people use the RCA output and a harness adapter to send the signal to the Bose amp.
Old Jul 22, 2009 | 09:45 PM
TroysG's Avatar
^^^ I do NOT recommend that unless you have a preout voltage of 4 or higher.
Old Jul 23, 2009 | 09:29 AM
Im a noob when it comes to audio stuff...Im looking at an eclipse head unit that has 4 voltage pre-outs. Im confused as what to do if the eclipse HU has a 22rms watt amp built in and how i install that with my bose amp that I have already in my car. Does anyone have a DIY for '06 gcoupe with a bose system?
Old Jul 23, 2009 | 09:38 AM
Dubi2087's Avatar
Honestly even with the new headunit and the factory bose amp, the sound quality still sucks IMHO. You would be better off changing the factory amp before changing the headunit.
Old Jul 23, 2009 | 10:30 AM
DjGenuine's Avatar
^^^ yeah...I just had installed an aftermarket no name double din unit from a groupbuy and the sound is horrible. I was told the BOSE amp doesnt work well with other brands and to run the unit without the amp connected. Either way this double din unit kinda sucks and I regret buying it
So.... I ended up purchasing a Kenwood DNX9140 and I am excited about getting this installed hopefully this weekend! Im going to see how better the sound is with the BOSE amp...if it still sucks, then I will end up changing the amp and getting a 12" or 15" sub in the trunk.
Old Jul 23, 2009 | 12:52 PM
Im fine with the quality of the bose speakers and amp right now..i just wanna know how to h/u the HU with a built in amp to my existing bose system?
Old Jul 23, 2009 | 08:11 PM
Gilley's Avatar
Get the Metra 70-7551 wire harness with RCA pigtails. Plug them into the female RCA jacks on your new HU, connect the wires of the white clips to the harness on the new HU, and then plug it into the stock harness. The connection is made.
Amazon Amazon
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
