04 coupe HU problem
Old Sep 13, 2009 | 06:57 PM
410g35's Avatar
04 coupe HU problem
I just got done installing a Kenwood deck into my 04 coupe and am not getting any sound out of my speakers. I installed the deck using the Metra 7550 harness rather than the 7551 harness because I plan on switching the speakers out. Is the stock amp causing the no sound problem? I've read that the bose system has low output and I imagine that this would be the problem that i'm running into. If I swap the stock amp for an aftermarket amp, will I be able to use the stock wiring to hook up the aftermarket speakers or do I need to run all new wiring? Is there a quick fix for my problem so that I can listen to music until actually switch my speakers out?
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
andyg35c1
Aug 29, 2015 03:37 PM
sailfish250
Jul 30, 2015 11:39 AM
attarday
Jul 15, 2015 04:03 PM
