Pre outs for double din
Old Sep 15, 2009 | 02:40 PM
350orG's Avatar
Just a quick question getting ready to install my dbl din
will 2 sets of preouts work while still keeping the bose amp
and the Pioneer 2 din I'm using has 2 sets of 4 volt preouts (Front and Rear/Sub). I was going to install all new amps, speakers and subs but I just figured it wasnt worth it.
also should i just use the 7751 wiring harness?
Thanks
Old Sep 15, 2009 | 07:34 PM
TroysG's Avatar
has the search button been disabled?
4 volt preouts SHOULD be fine to use with the 7551.
if you're installing amps for the interior speakers it doesn't matter which harness you use.
Old Sep 17, 2009 | 03:05 PM
pfarmer's Avatar
Thanks
Not sure about the year, but the Bose amp on mine uses balanced inputs. In this case if you want to keep the Bose amp you may want to go with a balanced transmitter which will take a unbalanced output such as RCAs and convert them to balance inputs. You would want to place the device as close to the source (the head unit) as possible to cut down on any noise to the Bose. The balance inputs will typically reject noise.
I have been looking at going the other way, that is keep the head unit on my 08 but go with aftermarket amps and speakers. In this case the balance reciever would be placed near the new amp since it would take the balance output of the head unit and convert it into unbalance RCA inputs. Most that do balance to unbalance conversions do so with inductor based units which are really designed to do the conversion for speaker level outputs.
Good luck!
Old Sep 17, 2009 | 04:37 PM
TroysG's Avatar
hey pfarmer, take a look at the audison 1bit as your interface, it's a lil pricey, but will DEFINITELY do the job you want it to
Old Sep 18, 2009 | 03:22 AM
pfarmer's Avatar
I actually look at it but was a little unsure if it really takes a low level balance input or was referring to speaker level balance inputs.
Old Sep 18, 2009 | 11:56 AM
TroysG's Avatar
I just read an article on it and it seems SUPER impressive, likely puts the cleansweep to shame.
Old Sep 18, 2009 | 02:18 PM
pfarmer's Avatar
To me it comes down to the ability of using low level balance inputs versus high level speaker level inputs. When I read the specs it didn't specificially mention this. One of the issues is that using the typical high levl speaker level inputs for low level balance inputs will often modify the frequency characteristics of the source signal due to the inductors often used in high level balance inputs designed for speaker level. Many processors will allow you to adjust for the levels but still use inductor based devices.
The fact is that the rest could be used for what I would think about doing anyway. For about 30 bucks per set of channels you can build balance receivers as a front end for a processor that doesn't handle low level balance inputs.
I would be looking at using no crossovers instead an amp channel for each speaker.
jsimonk
Dec 22, 2023 03:49 PM
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
EPG35
Aug 16, 2015 04:52 PM
itztwinki3
Aug 1, 2015 12:58 AM
kd03g99
Jul 30, 2015 11:24 AM
