How to upload HD video of Mod, Tod, or AVCHD videos to Youtube?
Old Sep 16, 2009 | 09:07 PM
brntkobe1's Avatar
High-definition video is now very popular in the market, not just for TV, but in various HD Camcorders (JVC, Panasonic, Canon, Sony, Sharp, etc).HD video involves display resolutions of 1280×720 pixels (720p) or1920×1080 pixels (1080i/1080p). Using the new formats like HDV(supports MPEG-2 compressed video, MPEG-1 Audio) and AVCHD(uses MPEG-4 H.264, also called AVC.), And all these camcorders usually record the video as MOD, TOD or AVCHD (M2TS, MTS) video files which need great power to display and edit. Then kinds of problems and troubles are going with it.
1, How to connect HD camcorder to computer and download the video?Themost popular way to connect an HD camcorder to your computer is to usean IEEE 1394 connection. The other option is USB 2.0, but USBconnectivity is not near as common as FireWire connection.
2, what media players can playback these HD Videos?
CyberLink PowerDVDand InterVideo WinDVDcanplay a wide variety of video and audio formats, including versions ofMPEG-2 and MPEG-4 and Windows Media Video, including WMV HD.
VLC media player is a highly portable multimedia playerandmultimedia framework capable of reading most audio and video formats (MPEG-2, MPEG-4, H.264, DivX, MPEG-1, mp3, ogg, aac …) as well as DVDs, Audio CDs, VCDs, and various streaming protocols.
Then some of these applications recognize the .M2T / .MTS MPEG transportstream file types by default, or can open them if you explicitly importthem. But some only can import the files if they are renamed to .MPG.
3, How to upload what you shoot with your HD camcorder to Youtube.
Because all our HD camcorders usually record the videos as MOD, TOD or AVCHD (M2TS, MTS) video files. And these files can not be uploaded directly to Youtube. So now what you need to do is to convert this tricky MOD, TOD or AVCHD (M2TS, MTS) formats to FLV, MP4, AVI, or WMV etc frequently-used formats. I usually useMoyea HD Video Converter Mac to do this job, now I will introduce my experience to you.
Moyea HD Video Converter for Mac is a professional and excellent tool for converting HD videos from HD camcorders and DVs (JVC, Panasonic, Cannon, Sony, etc.), or HD DVD and Blu-ray DVDto any other video formats. Even, you will never worry about out ofsyn, output quality, converting speed. It will run smoothly andperfectly as your wish.
First, download and install this Moyea HD video converter for Mac. After installation, please open it and your will see the follow interface.
Second, add files by clicking the “Add” buttonto import video files. Then you should select the output format youneed to convert and the destination folder you want to put. Click the “profile” drop-down list to select the format to FLV, or MP4, or WMV, or AVI etc. And click the folder icon in “output” to specify where to load your output files.
Third, set advanced settings. You can set the advanced settings to optimize the videos on changing Video Codec, Bit Rate, Video Size, Frame Rate, and Aspect Ratio of video as well as Audio Codec by clicking button “Setting”.
Fourth, click the “Editor”button to edit the video. You can adjust video brightness, contrast,and audio volume. In addition, you can also trim and crop video to bewhat you need.
Last, start converting, click the start button, and then video converting will begin, even more, you can choose “Apply to all”, or “Merge into one file”.
After these simple steps, all you need to do is to login to YouTube and upload these converted camcorder video formats.I wish all of these can help you more or less, in order to reduce your trouble caused by this HD era.
Joe Gargano
Sep 18, 2015 11:17 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
Red G Coupe
Video Share
Sep 12, 2015 03:09 AM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
INVADER_6MT
Sep 3, 2015 01:47 AM
