2006 g35C w/ compustar pro CM5000 brain
Old Nov 5, 2009 | 06:35 PM
nguy0750's Avatar
I'm looking for experts to help me look over this install. I guess I need someone had done this before and look over my wire mapped to tell did I make any mistake there?
CM5000 Main Harness: CN1
1) RED -- (+) 12v Constant - I got this.
2) GREEN/WHITE -- (+) Parking Light – I got this wire.
3) RED/WHITE -- (+) 12v Constant ( Separate Red/White prewired to 2nd Relay) -- this pin has two outputs. One is (red/white) I will connect to the 12V Constant on the G35'S IGNITION HARNESS. The other is pre-wired to a relay with the short violet wire on pin 85 and long blue wire on Pin 30. I can use this relay for my 2nd starter.
4) WHITE -- (+) Accessory - I got this wired.
5) VIOLET -- (-) When Armed prewired to Starter Kill Relay - this wire is pre-wired to a relay (to pin 6)
6) YELLOW -- (+) Starter ( Prewired to Starter Kill Relay) - I got this wire.
7) GREEN AND RED -- (+) Ignition and ( Separate Red prewired to Starter Kill Relay) - I got this wire.
BLACK -- (-) Ground
G35 INGITION SWITCH HARNESS:
1) 12 Volt Constant <--- connect to pin 1 (RED) and 3 (RED/WHITE)
2) Starter <--- connect to pin 6 (YELLOW)
3) Starter 2nd – use the blue wire on the pin 3 relay. Connect (-) starter output to the short purple wire to provide positive output.
4) Ignition 1 <---- connect to pin 7 (GREEN)
5) Accessory <---- connect to pin 4 (WHITE)
For the Blade. I'll just follow their instructions for the 4 wires from the 20 pin harness.
I have flashed my CM5000 with the lasted firmware and the Blade-al with the correct firmware for my car.
All I need it to work right now are to lock/unlock/trunk/auto start. Is that all the wire I need right?
Old Nov 9, 2009 | 02:30 PM
nguy0750's Avatar
I saw alot of people asking for a remote start on our G35 before but not alot of people know how to do it. I have the 2006 g35C w/ intelligent key.
I installed it and got everything worked. I carry the after market for remote start (1 mile range) only and use my factory key fob for everything else just like before. You can use the after market remote everything if you like.
Let me know if you need help on installing Compustar CM5000/w blade. You only have to connect 11 wires to get lock/unlock/trunk/and remote start to work.
Jiggerjuice
Aug 17, 2015 08:41 AM
Scootch
NorthEast
11
Aug 3, 2007 05:13 PM
bavarian06
Aug 22, 2006 04:44 PM
BlackBuzzard
G-SQUAD
21
Apr 10, 2005 10:07 AM
